09-07-2011, 10:39 AM | #1 |
PITbut
1981 Chevy 454. What oil do i use???
The engine is new. Its finally going to start driving. I did the joe gibbs break in oil and procedure.. What oil do i run??
delo 400? 10w 40? Its a standard flat tappet so i should be using something different then just standard oil right?
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
09-07-2011, 12:29 PM | #2 |
Re: 1981 Chevy 454. What oil do i use???
I use "Castroil Edge with Syntec Technology" 20W-50. It says right there on the back of the bottle "for use in classic cars equipped with flat-tappet camshafts". Or, I just saw that Rislone has come out with an additive that will allow you to run whatever oil you like. I might give that a try next time. Synthetics are expensive.
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS -1983 Chevy Silverado C1500- 383 stroker, TH400 -1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears -And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket "The only thing we have to fear is fear itself." -FDR (and maybe rust too) You've gotta be able to stop and steer before you can go fast! |
09-07-2011, 01:31 PM | #3 | |
PITbut
Brad Penn Joe Gibbs Racing or Valvoline VR1. It has the zinc in it. Here is the thing. That Castrol that you use, it says that its for use in that flat tappet cams, but heres what some people arent getting. When they are updating their oiling standards they are "supposed" to back date to older vehicles. But the truth is that it doesnt. This is just coming from my engine builder. I run what he says to run. Issue with the additive is how much exactly should you use?? Also there is an issue with the calcium in the non zinc oil that interacts with the zinc additive that also wears the cam.. Anywho. My thoughts were that if i ran synthetic i wouldnt have to worry about it... But i didnt get to ask him that. If synthetic is so good, wouldnt it stop premature cam wear???
09-07-2011, 02:53 PM | #4 |
Moderator
Just do what the engine builder recommends.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
09-07-2011, 03:29 PM | #5 |
~Rest In Peace~
i concor with led
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
09-07-2011, 09:07 PM | #6 |
There's a thread on the engine and drivetrain forum by Ticker that explains the different types of oils safe for use in these engines. My machinist said that the castroil will work fine. He said that Joe Gibbs oil is good too. Bottom line is, as long as you followed the proper break-in procedures on your cam, it should live a long, healthy life. The ZDDP just helps it last a lot longer.
09-07-2011, 11:01 PM | #7 |
Grandpa in the rustmobile...
Ive started to use valvoline vr1, it was on sale for 2.99 at orielly, i should've bought all they had its around $4.99 qt now.
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
09-07-2011, 11:26 PM | #8 |
PITbut
Whats the oil pressure supposed to be at idle, then at 2500?
09-07-2011, 11:34 PM | #9 |
I have an HD pump, about 50 or something at idle. I dont know.
Whats yours?
09-07-2011, 11:38 PM | #10 |
PITbut
WOW. 50?? Im 65 ish at 2500, and about 25-30 at idle.. hmmm
09-08-2011, 10:51 AM | #11 |
It'll Buff Out!
X3
You should be able to ask your builder how your oil pressure is compared to what he built, and ask if it's a stock pump or HP. Also A Good Napa Gold filter will help Oil pressure while a Fram will hurt it.
"Instructions are just another mans opinion" Become a Supporting Member http://67-72chevytrucks.com/vboard/payments.php Man Card Rules http://67-72chevytrucks.com/vboard/s...d.php?t=634550 72 Chevy Cheyenne Super 400 LWB |
09-08-2011, 11:18 AM | #12 |
Yours is fine. I think Napa filters are WIX
