Old 09-07-2011, 01:32 PM   #1
Slowtruk
Slowtruk's Avatar
Will a 65 radiator fit a 61 truck?
Like the title says
IBEW Electrician-Nick
1985 C20 Silverado
1965 C-10 short fleet
1961 c-10 Apache short fleet
2005 Chevy Suburban LT
2012 Hyundai Sonata
Slowtruk is offline   Reply With Quote
Old 09-07-2011, 02:24 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Will a 65 radiator fit a 61 truck?
I would think it would, however the frame rails on a 60-61 are wider than a 63-66. what does your current rad look like? how wide is it? does it mount on the cross member in front of the motor?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-07-2011, 02:44 PM   #3
jchav62
1962 C-10
jchav62's Avatar
It will fit. You may need to do some mods, but I'm sure you'd be able to make it work.
60-62 radiators mount differently than the ones for 63-66. The earlier rads mount with bolts on brackets on the sides of the radiator. The later ones 'rest' on pads on the front crossmember and are clamped down with a bracket that comes up from the hood latch...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 09-07-2011, 11:22 PM   #4
Captainfab
60-66 Nut
You will have to fabricate a crossmember to hold the saddles for the bottom to rest on. Then you will have to use the '63-'66 upper support.
