Old 09-07-2011, 02:21 PM   #1
srziemkowski
srziemkowski's Avatar
Factory steering column
66 c10 - i changed from a wooden steering wheel to a 68 c10 wheel and the po had hacked a bunch of things in the column,the wheel is very wobbly on the upper half and know there is something's missing,does anybody have a breakdown picture from the steering wheel to the housing that is attached to the dash so i can see what is missing? Is there supposed to be a bearing yet underneath the one in the turn signal switch?
srziemkowski is offline   Reply With Quote
Old 09-07-2011, 02:52 PM   #2
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: Factory steering column
All I have is this an original and not a 68 c10 wheel:
60 Steering column diagram
http://67-72chevytrucks.com/vboard/s....php?p=4551646
And this maybe helpfull as well:
http://www.americanclassic.com/asp/d...year=&ytype=to
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 09-07-2011, 03:20 PM   #3
srziemkowski
All the pictures get confusing,i am definetly missing the spring under the wheel,but the bottom picture on the first link looks like i am missing a sleeve,the second link gives a number for a bearing.???
Old 09-07-2011, 04:14 PM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
63-66 columns are different.
http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=82
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-07-2011, 04:21 PM   #5
srziemkowski
So 63-66 has no spring between t/s switch and wheel?, and the picture does not go deep enough to tell me if there is supposed to be a sleeve or bearing into the column jacket?
Old 09-07-2011, 05:46 PM   #6
Clyde65
Clyde65's Avatar
there is a spring in there, I believe it goes canceling cam, the wheel attaches and then the horn button retainer then a rubber grommet with the horn button.
mine, ( not installed or rebuilt) doesnt have a spring anywhere so maybe I am wrong. I dont have a wheel either. but this is what i was told a while back
Clyde65
Rebuild of Clyde
support our troops!
Old 09-08-2011, 08:45 AM   #7
srziemkowski
Ok,thank you all
Old 09-13-2011, 09:36 AM   #8
srziemkowski
Ok,so after not finding any local parts for a column spring,i decided to improvise,i used a spring from a duramax deisel thermostat,worked awesome,column and steering wheel are now tight.
Old 09-13-2011, 09:38 AM   #9
1Bad62Pro/Street
Talking Re: Factory steering column
Improvising... Good job!
There you go.
Old 09-13-2011, 09:47 AM   #10
srziemkowski
Benefit of working at a chevy dealer,look at parts on the shelf for what might work,get a used one from a technician,cut it apart,walla!!!!!
