Old 04-10-2003, 07:53 PM   #1
bookem
What tranny?
I'm picking up a 1967 swb this weekend, it has a 3speed 6 cyl and doesn't run. I am ordering a GM crate 350 for it and was trying to find a good 5 speed to match it. Any ideas...... Will any newer 5 speed match the current transfercase?
thanks ......... Dan
bookem is offline   Reply With Quote
Old 04-10-2003, 09:20 PM   #2
GMC71k20
get a NV4500, advance adapters sells kits to mate it to older t-cases.
GMC71k20 is offline   Reply With Quote
Old 04-11-2003, 12:51 AM   #3
Scrub
Collector of rusty Items
Scrub's Avatar
Is your truck a divorced case? I would guess it is divorced and a rockwell in a 67.
You could put an NV4500 with a 2wd output to the divorced case. I called Advanced and asked about this, and they recomended a Dodge trany. They said it would adapt easier (go figure)
That wasn't to bad for cost because you only need to adapt the engine side of the tranny. The driveline handles the rear.
If you have a mated t-case it is more money as you must adapt the front to the motor and the rear to the t-case.
A mated NV4500 is going to cost about 2500 bucks. The trannys are like 1200 and the adapters are about the same (I think)
There is not much other choice. You can get a SM465 mated to a NP205 for about 500 bucks, which is what I am doing for now. Some day I will go for the divorced version of the 5 speed.
Good Luck
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 04-11-2003, 12:58 AM   #4
1969 GMC
1969 GMC's Avatar
I know that when I first joined this messge board, I wanted to know what t-case I had. It sounded to me like GM used divorced Rockwells early in production (67-68) and then married NP205 (70-72) but 1969, the year my GMC was made, you could have gotten a few. Married NP205, divorced Rockwell, and married Rockwell (what I have). So unless someone's done a t-case swap, I'd venture a stab at it being a divorced Rockwell.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
