Old 04-10-2003, 08:09 PM   #1
ocbaud
Garage Queen Material
Email to sportstruck direct.
I installed a set of your Western Chassis 2.5" spindles at around the first of January and I was having trouble getting the drivers side inner bearing to go on all the way. After it was finally on, it drove fine, until recently when the truck started to make a loud scraping sound everynow and then. After a couple days of it doing that, I thought I narrowed it down to a bearing in the drivers side. I go to take the rotors off of there, and its stuck, i finally have to yank the rotor off, to find that the inner bearing had dug itself about 1/2" into the spindle. I had to cut part of the bearing to get it off to see how bad it was. I replaced the bearing and since then it has been making a semi-loud "chachacha" sound everytime the wheel turns. I couldnt find an email address for Western Chassis so I am emailing you. I was sure I put enought bearing grease on there, so i dont know what the problem was. Any way, I need to have this spindle replaced or something, because i know it is not safe driving like this. Thanks.
i just sent that to them cause i couldnt find an email for western chassis. Hopefully they will replace it or let me order just one new spindle.
ocbaud is offline   Reply With Quote
Old 04-10-2003, 08:21 PM   #2
Nvbowtie
Nvbowtie's Avatar
Possible ??
Not sure if this is the same or spin off ????
hope it helps !!
WESTERN CHASSIS RACING COMPONENTS
2550 S. East Ave., Suite 101 Fresno, Ca 93706 PH: (559)266-4844 or (559)266-2133 Order Fax: (559)266-4864
www.unlimited2u.com/chevy
1980 Chevy C-10 Silverado
1988 Chevy Blazer Tahoe
Nvbowtie is offline   Reply With Quote
Old 04-10-2003, 08:28 PM   #3
ocbaud
Re: Possible ??
hope it helps !!
http://www.westernracing.net
nope, not them
Old 04-11-2003, 07:55 PM   #4
Nvbowtie
Nvbowtie's Avatar
Hard Phone # to find
No- **** The website you found is not the same----
for the # I posted ****
( *** You found this somehow ***)
Western Racing Components
42255 C Baldaray Circle Temecula, CA. 92590
Phone: (909) 587-6776
Again- Westren Chassis
Tanney Machine & MFG
2510 South East Avenue
Fresno, CA 93706
** ***Here is your number:
Ask for Westren Chassis,
they have Receptionist that answers calls to the building they are in.
Westren Chassis
559-266-4844. Ask for Rhonda or Willie.
Old 04-18-2003, 11:32 PM   #5
gldevall
gldevall's Avatar
Eric,
Have you heard anything on your spindle?
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 04-19-2003, 12:12 AM   #6
ocbaud
Originally posted by gldevall
Eric,
i talked to western chassis and they said to contact sports truck direct to see about purchasing a replacement spindle.
i sent a second email to them about half a week ago, and still no reply from either message i sent to them
