Old 09-07-2011, 05:00 PM   #1
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Question Front to rear brake line question
Is the front to rear brake line 1 piece from the factory? That being from the master to the rear brake hose.
I bought some bulk (25') tubing so I could make it in one piece but want it to be correct so can piece it. This is a 69 C30 by the way.
If it's in 2 pieces, where would they be split?
Thanks,
Bob
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 09-07-2011, 05:15 PM   #2
webfoot
Re: Front to rear brake line question
one piece back to a splitter on the rearend which sends a line laterally to each wheel cylinder.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 09-07-2011, 06:19 PM   #3
cdowns
cdowns's Avatar
3pieces/from master to the rear hose
from master cyl to proportion valve//first piece
from proportion valve to the front crossmember//second piece
from about6"in on the crossmember then accross to pass frame rail back to rearend// number three
Old 09-07-2011, 06:57 PM   #4
bobs409
bobs409's Avatar
Mine has drums so no prop valve but it does have the distribution block or whatever it's called (warning light wire goes to it)
I do have the small line from master to that block that is still good condition.
So I'll put a union 6 inches from driver side on crossmember. 3 lines it is.
Thanks,
Bob
Bob
