Old 09-07-2011, 08:36 PM   #1
chop_shop
want to go air ride... have a few ?
Ok. So I really want to put my 65 on air. I know alittle about air ride. So i want to know what i need for bags? what is a good cheap management setup. Im not looking to lay frame right now. But might later in time. I do alot of fab work of a living. So that end is not a problem. I will be hualing with it. Nothing crazy. Just a harley from time to time and some parts.
I was thinking about a manual valve setup. Two comps and maybe a five gallon tank.
Also where is a good place to buy from? I am on a budget. This truck is my daily driver and i still have alot to do before winter gets here. And its coming quick...
chop_shop is offline   Reply With Quote
Old 09-07-2011, 11:10 PM   #2
62 Bowtie
62 Bowtie's Avatar
Re: want to go air ride... have a few ?
check out the suspension forum lots of good info i have ss7 bags all 4 corners and accuair valve assembly 2 viair 380 coppressors and a 7 gal tank 78 front susp in front stock with trail arm in rear just put the bags in place of the stock springs
62 Bowtie is offline   Reply With Quote
Old 09-08-2011, 10:12 AM   #3
creep
Registered Loser
creep's Avatar
I got all of my air ride stuff from Quality Air Ride ( formerly ***************** ). I got a 5 gal tank, Viair 480 compressor, 8 valves, 3 gauges, 4 bags, controller, air line, pressure switch and water seperator for around $900. They are located in IN so shipping to KY shouldn't be too bad.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 09-08-2011, 10:16 AM   #4
creep
Registered Loser
creep's Avatar
Sounds like you want something like this...
http://*************/air-management/a...minator-bags-5
Old 09-08-2011, 10:19 AM   #5
PGSigns
PGSigns's Avatar
Check with AVS Jason in the vendors section. He will put a package deal together. When I did mine I put the 2" deep cups in the lower A arms and just used the mounting plates he has in the back. Used the 2600 bags all round. I used the simple controls using 4 rocker switches and the gages that show two bags on each one. Plumbed it all with 3/8 tubes. Works just fine.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-08-2011, 10:23 AM   #6
chop_shop
Cool! Thanks for the info guys.
Old 09-08-2011, 10:24 AM   #7
chop_shop
got any pics of your cup setup?
Old 09-08-2011, 10:40 AM   #8
joedoh
joedoh's Avatar
gauge store has the best prices and ships faster than anyone. other shops will gladly take your order and let everything grow old on back order.
store.gaugemagazine.com
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 09-08-2011, 12:24 PM   #9
jimmydean
jimmydean's Avatar
Check out the suspension forum. I learned more there than anywhere about bags, valves, compressors, everything you could ever WANT to know is there. Also check out the Vendor Market as they run some sick deals.
I know there were some great intro kits last I looked (paddle valves, shrader kits). It depends on how low you want to go, how much work you want to do, and how much you want to spend.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 09-08-2011, 12:37 PM   #10
kieth
kieth's Avatar
I went to the gauge store, they have very good prices, started to order a valve and found that their freight rates are ridiculous, I ordered the same part on line for $10.00 less due to their ridiculous freight rates......
valve was 30.00 at gauge store shipping 19.95 made the part 49.95
ordered online at hornblaster cost with freight $39.95
I am getting ready to order some other air suspension things, I will talk to them about the freight rates before ordering from someone else. Kieth
kieth is offline   Reply With Quote
Old 09-08-2011, 12:38 PM   #11
chop_shop
Well. Im not looking to lay frame. I have all of the stock front barkes out of a 74 c10. So no drop spindles. I think im going to cup the lower control arms and do a small notch in the rear. Ill get the front down first and make the rear match up. I really dont want to raise the floor of the bed up much. I still need to use it as a truck...
My money is kind of tight right now. Im also build an old shovel that is taking alot of my time and money. Thats why i want to go low buck management and fab as much as i can.
Old 09-08-2011, 02:24 PM   #12
PGSigns
PGSigns's Avatar
Here is a link to my build thread. I need to update it but I think it shows a lot of the same things you are thinking about doing.
Jimmy
http://67-72chevytrucks.com/vboard/s...ghlight=yeller
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 09-08-2011, 02:31 PM   #13
chop_shop
Thanks for the link. Nice truck!
Old 09-08-2011, 03:09 PM   #14
joedoh
joedoh's Avatar
well if you just want one valve, it makes sense to go for the lowest total price. but what I was really saying is, hear me now and believe me later, if you order a bunch of stuff from another vendor there will likely come a day close to 3 weeks after you place the order that you would gladly pay an extra $100 to just receive your full order.
Old 09-09-2011, 11:08 AM   #15
kieth
kieth's Avatar
I have nothing against these folks, just wanted to make people aware, 19.95 to ship a 1 lb valve is kind of crazy, could not imagine how much a complete system would cost, I mfg big truck components and freight is a very important factor any more......I thought almost 20.00 was l little excessive...JMO Kieth
Old 09-09-2011, 04:34 PM   #16
Dustin07
Stirrer of the Pot
Jimmy
I just want to say x's 2 for AVS. I have spent a lot of money there and still wear my AVS shirt religiously lol. good people. I used to work with Kris who is not there anymore i believe.
Dustin07 is offline   Reply With Quote
Old 09-09-2011, 05:48 PM   #17
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: want to go air ride... have a few ?
Nice........
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 09-09-2011, 09:10 PM   #18
Dustin07
Stirrer of the Pot
Originally Posted by 1Bad62Pro/Street View Post
Nice........
yeah that setup is almost identical to mine. except front end is not done yet... hopefully within a month or so.
Old 09-09-2011, 11:02 PM   #19
joedoh
joedoh's Avatar
well, looks like most of a complete system would be 56 bucks, which isnt bad for compressor, tank, valves, front brackets, bags, airline, switchbox, yada yada
sounds like 20 bucks might be their minimum charge.
and I am not a shill for them, just a guy who has ordered from everyone twice and knows who ships stuff and who takes my money and ships whenever they darn well feel like it. order from the guys with the cool website, the guys with the best prices, the guys with the lowest total shipping, whatever, its not up to me.
