Old 09-07-2011, 09:32 PM   #1
Tmwoodall
350 Top End + Misc Parts
This was all pulled off of a running engine that I bought with a frame and cab. I have just decided to beef it up a good bit and replace all of the following:
$15 -Oil Pump - I believe it is a Melling stock replacement
$10- Fuel Pump - Plain ole' carter
$100 - Distributor - Mallory 5048021
$50 - Intake - No name made in china polished, in good shape just needs some cleaning and polishing
$275 - Heads - Reworked 882, setup for a cam with max lift of .510
$40 - Rockers - Stock stamped
$10 - Pushrods - Forgot to measure, but can if someone wants them individually
$20 - Water Pump - Chrome no name, in good shape outside, oxidation inside
$40 - Alternator - Brand new from O'reillys (I personally bought this), has some flaking on the chrome.
$30 - Flex Fan - I also purchased this piece personally, can/will include aluminum spacer.
$50/ea -2 GM AC condensors never had either one running so not sure of shape but they appear to be in good shape.
I also have brackets and pulleys for all of this. Some are orange powdered, one or two are black and in need of freshening. I am moving over to a serpentine kit this weekend.
As far as I know this all has about ten minutes of run time on it. When I bought the truck the engine was said to have never been fired, and looked the part. I ran it all on the bench for about 5-10 minutes several years ago. The heads need a new coat of paint and a good gasket scraping. The intake could use some elbow grease (aka polishing). If you have any questions shoot them over my way. If it is still in the ad, it is still for sale. If you simply ask "is it for sale, I'll quickly delete your email. Spammers need not apply, I can spot you a mile away.
The more you buy, the more I am willing the deal. I need the bench space back. I may also have a new power steering pump available if my new serpentine kit mounts in ok. Rest of the picture set can be viewed here: http://gallery.me.com/tmwoodall#100083
Prefer to stay local on the heads, willing to ship the rest.
www.tomthetruck.blogspot.com <-- Aka build thread.
Last edited by Tmwoodall; 09-08-2011 at 12:58 PM. Reason: Update to correct PN on Dist.
Tmwoodall is offline   Reply With Quote
Old 09-08-2011, 12:14 PM   #2
Tmwoodall
Re: 350 Top End + Misc Parts
ttt
Old 09-19-2011, 11:26 PM   #3
Tmwoodall
TTT, OBO on all of it.
