09-07-2011, 10:06 PM | #1 |
C10 and C20 under bed tire carrier difference
Picked up a under bed tire carrier from the wrecking yard yesterday. Cleaned it up and Im currently attempting to mount the spare tire on it. The carrier came off a C20 and its going on a C10. Two questions. 1. Does the tire mount with the outside of the rim facing up? 2. Are the carrier brackets suppose to fit flush to the inside of the rims? Ive got about a inch of free space, leading me to think that the carrier is made for a larger rim. Give me a few and I'll see if I can get a picture uploaded. Thanks in advance.
USCG "Support Search & Rescue, Get Lost" |
09-07-2011, 10:11 PM | #2 |
Re: C10 and C20 under bed tire carrier difference
Pictures for your viewing pleasure...
09-07-2011, 10:26 PM | #3 |
There are several extra holes to change the bracket to accomidate size wheels.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
09-07-2011, 10:50 PM | #4 |
Looks like thats the path Im heading down. Unfortunately Im going to have to do some drilling because the brackets are currently secured with some heavy duty rivets. Should be easy enough to secure them with some new bolts. Thanks for the reply.
09-08-2011, 02:56 AM | #5 |
Moderator
a cut off wheel and an air chisel is the fastest/easiest way to remove rivets. cut an "x" into the rivet head and the four pieces pop right off with the chisel. i had to do the same thing to my underbed carrier.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
09-08-2011, 03:08 AM | #6 |
I'm gonna guess you need to flip the rim over so the tire mounts flush with the bracket and then you won't scratch the crap out of your rim!! Good luck.
Going out on a limb here, but do you also need to secure the rim to the bracket( with a long bolt) so it doesn't move around on you?? |
09-08-2011, 10:15 AM | #7 |
in the past i've taken 1/8"rubber pieces and glued them on to the prong things to protect my wheels from scratches
