RAT1968 '68 Cab/'71 Parts
Fluid Day. Oh Oh, Tranny Is A Fountain!!!
The P.O., who is a 20 year-long-plus friend, told me of the trans fluid spilling all over when he drove the truck home the 20 miles he had it before selling it to me. His son, a Certified GM Mechanic, said, "Usually", the TH350 leaks as a result of needing pan gaskets, or seals.
I bought filter, pan gasket and good seals. I had a guy who professed about 200 trans rebuilds to his credit put 'em in. I watched him, for whatever that was worth. I had a new one piece drive shaft built that I haven't installed yet. So, today, I put in six quarts of ATF. It was fine until 5 (I think). At least no leaks I saw. Then I put the last one in. I went away to do something else and heard a nasty waterfall sound. Looked under the truck (I didn't have to look too far) and say t. fluid pouring out of the rear of the trans. Now, I'm a rookie on transmissions. I don't know if the slip joint on the drive shaft is supposed to "hold back" fluid coming down the splines via the seal in the rear, or not. Seems unlikely. I can't really tell for sure, but I think about a quart and a half poured on the floor... pouring off of the bottom of the spline until it was just a steady trickle and then stopped. You guys could save me some time, money, and pain if you told me: "You are an idiot. Hook up your drive shaft...and don't put any more ATF in there until you run it". Or even, "Oh, oh. You're probably screwed. Pull the tranny and take it somewhere for a diagnosis...it's not supposed to puke out of back there." Well, at least I got the master cylinder bench-bled and the hood primered today.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
Re: Fluid Day. Oh Oh, Tranny Is A Fountain!!!
Put the drive shaft in, start it and check the fluid. Then fill if/as needed.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Champagne Taste on Beer Budget
Yup! Lee H nailed it.
You need to have the driveshaft in BEFORE adding trans fuild. Then you should be fine.
Coming Soon: Project 1970 Country Truck |
![]() Join Date: Nov 2007
It's all open passage from the pan to the tailshaft, so if you fill the tranny up with fluid beyond the bottom of the rear seal it'll gush every drop from then on out of there without the yoke in there.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
Yep, you gotta have a yoke in to hold the fluid in.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
Nice valve covers and breather.
I'm not as good as I once was, But I'm as good once as I ever was. |
454 MAKES IT ROAR
Sorta like filling the bath without the plug in...
![]() the good news is there is nothing wrong with your tranny. Just for my own amusement I sometimes like to put folks address into Google Earth, just to see what it's like where you guys live....and sometimes you get a little surprise. This is what I got when I typed in Coarsegold CA where you are magwakeenercew2jh.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger Last edited by eightbanger; 09-08-2011 at 04:58 PM. |
~Rest In Peace~
is that driveshaft yoke screwed up or is it my eyes it looks like its bent on one side
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
Thanks, everyone. I was done for the day. But you guys inspired me to go back to the shop and get all cruddy again.
I put the drive shaft in and finger-tightened the yoke clamps at the differential end. I'm a happy man. My picture gave a little optical "conclusion" on the slip joint straightness. It was the flash or something. That was cool on the Google Earth pic. That wasn't me in the truck. Great Forum Irony.... There's a light at that corner now. Thanks to living in the Boonies, Google's camera cars don't get here too often. You all made me happy. And, who's to say we can't still learn anything at 65, eh?
I will take this a step farther on how to fill....
If this is a new/ fresh re-build, pour 4 quarts in it (with drive shaft in) and run for 20 seconds Pour 4 more quarts in start engine, check and fill to full hot. I have seen a new re-build th transmission puke all of the fluid back out the dip stick tube if filled all at once. |
