09-08-2011, 04:28 PM | #1 |
Lower control arm installation
When you re-install your lower control arms, how do you know where to line the CA as far as the little u-bolts go. Is there only one way they can be installed? I'm concerned I won't know how far back or forward to put them.
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
09-08-2011, 04:46 PM | #2 |
Re: Lower control arm installation
I set mine to the wheel base (133" on my longhorn) I used a c-clamp to hold the tape measure, then set to the centerline of the lower ball joint. Don't forget to subtract half of the diameter of the rear axle tube.
09-08-2011, 05:09 PM | #3 |
454 MAKES IT ROAR
It should have a small indent on the CA shaft (see pic) that in turn locates on a nipple on the underside of the crossmember, then just tighten up your u-bolts, and provided your shaft is centered on the CA thats all you need to do.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
09-09-2011, 03:53 PM | #4 |
Restoration Virgin!
eightbanger is right on the money!!!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
09-11-2011, 07:45 AM | #5 |
Thanks, guys!!
