Old 04-10-2003, 10:53 PM   #1
Scrub
Collector of rusty Items
Scrub's Avatar
How to put larger u-joints into a 205?
I am going to put 1410 u-joints into my 72 chevy.
What do I have to do to get the larger yokes for the Np205 t-case.
I know I need an output shaft with more splines, and they came stock in some Fords. I think that was only for the front. What do I need to the rear?
Any help is appreciated.
Thanks in advance.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 04-11-2003, 11:12 AM   #2
SuperStock46872
If it were me, I would just go with 1350's, because that is what 3/4 and 1 ton chevy's had stock. so the parts are easy to find. All you have to do is get the 1350 yokes off of another 205 or even a 203. the 203 is your best bet for the rear yoke because they are ultra common and most people are glad to part with them. For the front, your '72 205 will most likely have the corse splined output, so you are going to have to find a 1350 yoke out of an old truck. I do not beleive that they ever made a corse slined 4 bolt cv drive flange. I dont think there are any corse splined 203's but I could be wrong.
Hope that helps.
1972 Chevy K10
"Warmed Over" 468
Dana 60 front
Dana 70 rear
8 1/2" lift
38" Swampers
SuperStock46872 is offline   Reply With Quote
Old 04-14-2003, 10:31 AM   #3
TX_Mudder
Jess at High Angle Driveline can supply you with what you need.
Your 205, if original, has the 10-spline front output shaft. They make a 1350 yoke for it, but I really doubt there is a 1410.
If you indeed use a Ford 32 spline output shaft, then yes you can get a 1410.
Jess at High Angle Driveline can supply you with all the 1410 yokes and driveshafts you need.
If you do upgrade to the 32 spline front output shaft, let us know how it went because I am considering the same upgrade.
-- Mike
TX_Mudder is offline   Reply With Quote
Old 04-15-2003, 12:21 AM   #4
Scrub
Scrub's Avatar
Thanks Mike,
It will probably be a while before get to it.
Does anyone know about a Dodge NP205 t-case? I have a divorced version somewhere. Does it have the larger splines?
Thanks in advance again
Scrub
Old 04-15-2003, 01:09 PM   #5
SuperStock46872
As for changing to the new style, fine-splined output in the 205 it is a direct swap that can be done with the case installed and only requires the removal of the front drive shaft and the cover on the back of the case directly behind the front output shaft. It inly took me about 2 hours at the most, pretty straight forward.
1972 Chevy K10
"Warmed Over" 468
Dana 60 front
Dana 70 rear
8 1/2" lift
38" Swampers
Old 04-15-2003, 03:29 PM   #6
Scrub
Scrub's Avatar
I found a pretty good page on how to do this at:
http://www.alaskaoffroad.com/tech_2.htm
I bought a Dodge 203 and a Dodge 205 t-case on ebay last night for $57.83. It is in the next town, so no freight. I guess I will find out about a Dodge case real soon. Doubler anyone?
I kinda feel sorry for the guy selling it, But he had no picture. Maybe I will feel sorry for myself after I see them
Scrub
Old 04-15-2003, 11:36 PM   #7
Scrub
Scrub's Avatar
Yahoo,
I called the guy and he said he thought the Dodge 205 t-case had 1410 joints.
The good Lord surely watches over fools like me!!
Scrub
Old 04-16-2003, 12:02 AM   #8
Rod
Found this on ujoints...
http://coloradok5.com/ctm-d44.shtml
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
