09-08-2011, 09:24 PM | #1 |
Old Heap Driver
Hood Safety Catch/Lever (1950)
I finally picked up a hood last night for my '50. Shouldn't there be a safety catch next to the latch pin? I've looked all over a couple of the vendor sites but I can't find a listing for a "safety catch".
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
09-09-2011, 11:58 AM | #2 |
Re: Hood Safety Catch/Lever (1950)
I am looking for one also!
There must be something out there we can use...................ANyone !!!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
09-09-2011, 08:10 PM | #3 |
Old Heap Driver
Maybe someone could post some good clear pictures of the stock setup? Maybe some measurements as well? With all the cars and trucks using a safety catch we should be able to figure one out that's close to stock.
09-09-2011, 09:03 PM | #4 |
AD Addict
It is a stamped steel hook with a spring and a rivet. They are famous for broken springs around here. I've got 2-3 hoods like that. I can't believe they'd be that hard to find. I have a rotted out hood that I'll check to see if it is any good so I can re-spring mine! Half the battle with them is when the springs go bad in them, they won't 'center' themselves and you end up smacking them on the latch plate.
09-10-2011, 01:23 PM | #5 |
1970 Nova 327/T5 (my 1st car) 1971 K-20 350/350/205 (winter DD) 1953 GMC Suburban 1968 Chevy Bel Air 1976 Chev C-10 1972 Skylark (suncoupe) 1 of 3943 made |
09-10-2011, 02:53 PM | #6 |
Old Heap Driver
YES!!!
I'll take it! LOL!
09-10-2011, 07:20 PM | #7 |
If it has a good spring in it, I will take one also!!!
09-10-2011, 10:08 PM | #8 |
I need one too! Anyone else have one?
Robert C. 1950 3600 3600 re-do, shortening it up If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. |
09-10-2011, 11:37 PM | #9 |
Old Heap Driver
Parts Vendors......Are you reading this?
09-11-2011, 12:09 AM | #10 |
I just sold one of those panels to a guy on another board for $40 shipped.
09-11-2011, 04:01 AM | #11 |
Just took mine out to paint it and yes it has a broken spring.
I think a junkyard tour is inevitable to look for suitable donors. If I find anything i'll let you know. I also managed to break the spot welds trying to unseize the pin adjustment..... |
09-11-2011, 08:59 AM | #12 |
Old Heap Driver
I'd really like a measurement from red dot to red dot. A bazillion cars used this type of safety latch I'm sure a suitable donor could be found or I'll make one.
09-11-2011, 11:32 PM | #13 |
That is the original hood off of my 50 3100. The latch worked good when I took it off of the truck 7 years ago because the hood got trashed when a girl on a cell phone ran a stop sign in front of me. The latch is good the brace is bent. What do I need to check for you. I have no need for it so I could sell it. I kept the hood because I hate to throw stuff away.
09-11-2011, 11:47 PM | #14 | |
Old Heap Driver
09-21-2011, 12:38 AM | #15 |
I just found one on Ebay. They show up there from time to time.
09-21-2011, 02:49 PM | #16 |
Anyone consider one of these from Autoloc?
Looks like it has a mount for a pull cable too! They cost $35. http://www.autoloc.com/catalog/Bear-...Latch-Assembly Last edited by Atomsplitter; 09-21-2011 at 02:58 PM. |
09-21-2011, 10:10 PM | #17 |
Let me know who else needs one and I will look around. I know of a junk yard that has probably 8 or so 1.5 tons if they are the same latch.
09-27-2011, 07:36 PM | #18 | |
I actually looked long and hard at that one myself before deciding to keep the original setup.
09-28-2011, 01:15 AM | #19 |
Put me on the list!
09-28-2011, 10:27 AM | #20 |
If I can find mine I'll sell it. I used my S10 latch for mine and cut the old unit off.
09-28-2011, 11:19 AM | #21 | |
09-28-2011, 03:23 PM | #22 |
I have been asked to supply details about my aftermarket (Not stock) hood latch. I bought mine from a company called Don's Street Rods which is no longer in business.
The one that is close to mine (pictured) is from Watsons Streetworks. The main difference with mine is mine has a metal cage (structure) around the plastic housing providing more strength. This latch just requires one hole for the striker as well as (2) small mounting holes. There is no safety cable or latch. And I didn't pay $110.00 for mine. That seems high. It seems to do the trick for my set up. Thanks
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
09-28-2011, 03:44 PM | #23 |
For anyone intersted, I saw this at Hot Augusts Nights in Reno last month. Kind of an ingeniously simple and cheap lock for your hood. I'm planning on doing this. I will use one on either side but one alone would PROBABLY work ok. Available at near any hardware store for $5.
I'd put a small polished stainless plate over the hole to eliminate chipping the paint: |
