![]() Join Date: May 2010
AC Removal
Guys, My AC compressor is shot and I just want to yank the AC out.
Is there anything I need to do other than disconnecting from the ac condenser and the firewall? Are there plugs coming out of the firewall? Or is there something that I need to weld? Is the large black box for AC? I thought it also has something to do with the heater core... |
![]() Join Date: Oct 2009
Re: AC Removal
The large box is the A/C evaporator and blower. If you want to keep a heater, which is inside the truck, you need to leave that box in place. Disconnect the pipe from the condenser to the A/C box, and the pipe from the A/C box to the compressor, cap them off, and that should do it. The two hoses that come out through the firewall right below the top circle on your picture are for the heater, as is the the vacuum-operated valve in your bottom circle. Also don't forget to terminate the wire that goes to the compressor - depending on how you have your controls set, that can be hot.
1971 C10 Longbed, 350/TH350 |
Re: AC Removal
Should I use anything specific to cap them off?
And which wire goes to the compressor to terminate? The vaccum operated valve you mention. Does this stay as well? |
Re: AC Removal
Your best bet is to remove EVERYTHING a/c related and send it to me!
-Scott- |
Re: AC Removal
I'd be willing to dump and or sell all this if I can figure how to yank it out
Re: AC Removal
Where you located in St. Louis? I live in Rolla and might be able to come help. If you want to PM me a phone number or address we can get together.
-Scott- |
Re: AC Removal
Thanks for the offer, but Im a good 1hr 45min out from you in Saint Charles County. Thanks though! I will wing it I guess from what 48Richard said.
Re: AC Removal
What can I use to cap those off with? Hardware store items? Anything in particular? I'm quite a n00b when it comes to these things.
#9 | |
Re: AC Removal
You just want to keep the chunks out. Legally you can't blow that R12 into the atmposhere but if you do the way to do it is to crack the fitting loose by the POA valve and let it out slowly. Posted via Mobile Device
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
