Old 09-09-2011, 02:54 PM   #1
camshaftgsxr
camshaftgsxr's Avatar
2.5 inch drop spindles are pinching my brake lines
has anyone else had this problem? it seems im going to need to rubber lines and new banjo fitting
the brake line is coming off of the caliper and where it turns to rubber it is getting pinched by the top part of the spindle.
would grinding a small amount of metal off of the upper spindle arm cause the spindle to become un safe or weak?
heres a picture
camshaftgsxr is offline   Reply With Quote
Old 09-09-2011, 03:38 PM   #2
camshaftgsxr
Re: 2.5 inch drop spindles are pinching my brake lines
never mind i got it, admin delete it if you'd like
Old 09-09-2011, 04:25 PM   #3
tazman87
tazman87's Avatar
i ordered an old dodge flex line with the opposite 90 on it..worked good for me
tazman87 is offline   Reply With Quote
Old 09-09-2011, 04:34 PM   #4
camshaftgsxr
i took a big screw driver and lightly (very lightly) pushed them off of the spindles, it fixed it, however im going to leave it parked for a few days to make sure the lines dont leak, my dad has taught me a lot but he always emphasized being careful with brakes. "if it wont go you have a problem, if it wont stop you're screwed"
Old 09-09-2011, 05:18 PM   #5
SBTork
Garage wrench
SBTork's Avatar
Good advice from pops. You'll be fine, this is a standard issue/fix with drop spindles.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 09-09-2011, 05:20 PM   #6
camshaftgsxr
thats good to hear i was wonder if my brake lines were messed up
Old 09-09-2011, 05:33 PM   #7
mooseknuckles
mooseknuckles's Avatar
mine were the same way......I had to bend the line a little, and had to pull it out of the clamp.
mooseknuckles is offline   Reply With Quote
