Need help with fuel gauge after new tank installation
So, I installed a 69 camaro tank today (following the outline by 67slider). Everything is installed, I still have to run my new fuel lines and pull the old tank. My question is this: how do I wire (or attach) the new tank to my fuel gauge. It may be really simple, but that wasn't covered in the write up of the install. Thanks for any help.
Old member
Take the wire off the old tank. Make it long enough to reach the new tank. Done.
![]() ![]() Factory truck tank hookup vented: Factory non vented: Take this wire which is ran up to the dash and extended it back to the new tank and connect it. ![]() ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
