09-09-2011, 10:34 PM | #1 |
Need some info on adding PS to 68 K10
I'm going to look at a 68 swb k10 tomorrow that is basically a plain jane. It currently has no PS or PB. Adding the PB is no problem, but need some info on adding PS.
Assuming is has the frame dimple, what can I use as a donor to get a power steering box from? I have one from a 86 2x4 but know there r differences in the pitman arm. Can I just put a 4x4 pitman arm on the 2x4 steering box? If not can I use a steering box from an 86 4x4 3/4 ton, or does it have to come from a 1/2 ton? Any info is most appreciated. Thanks guys!
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
09-10-2011, 05:26 AM | #2 |
Re: Need some info on adding PS to 68 K10
A 4x4 pitman arm will not fit a 2wd steering box.
I believe the only issue that you will have with the 86 3/4 ton 4x4 box will be the fittings for the lines. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
09-10-2011, 09:10 AM | #3 |
Thanks Jim, appreciate the info.
