Old 09-10-2011, 03:57 AM   #1
71 GMCDRVR
71 GMCDRVR's Avatar
Switching lug patterns
I currently have an 8 lug set up, but want to switch to 5 or six. Can this be done by switching the axles in the rear or do I need a new rear end? Also the front is disc brake (71, 3/4 ton) can I just switch the Hub/Rotor with a half ton Hub/Rotor, or am I gonna need new spindles and the whole nine?????
Blessings, Ryan G
JESUS IS LORD!!!!!!
71 GMCDRVR is offline   Reply With Quote
Old 09-30-2011, 06:40 PM   #2
68Gold/white
Re: Switching lug patterns
There are different ways to do this, but the easiest would to be find a donor 71 or 72 C-10 Pickup (71 and 72's all have disc brakes, disc brakes were an opton in 70, just look for the 5 lugs...), and swap the rear end, and front end. The whole front crossmember is bolted in, and can be transplanted into yours, if the rear springs are the same...
I guess I should have asked if yours is leaf spring or coil??? That will make a difference. The most sommon C-10 stuff will be coil spring. Leaf springs are an option on half ton stuff, though seldom seen.
68Gold/white is offline   Reply With Quote
Old 09-30-2011, 11:15 PM   #3
sleepertruck72
sleepertruck72's Avatar
I would guess the rear end would need to be changed out completely and the front end would take the whole nine . Again that just a guess on my behalf
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 10-01-2011, 04:35 AM   #4
71 GMCDRVR
71 GMCDRVR's Avatar
Hey sleeper, Im in turlock too, maybe seen you driving round town huh
I'm in a beat up blue GMC....but she sure is fast!!!!!
Blessings, Ryan G
JESUS IS LORD!!!!!!
Old 10-01-2011, 02:10 PM   #5
sleepertruck72
GMCDRVR,
Its possible you may have seen me, Ive been known to get around Im willing to bet your GMC isnt as beat up as mine But as long as she takes me where I need to go, its all good
72 C20 Longbed
05 1500 Z71
