Old 09-10-2011, 09:48 AM   #1
8door
Not too old to learn
What years Automatic shift pointer ?
There is a difference in the shape of shift pointers
on the steering column.
Is the difference in shape between tilt column and
non-tilt or model year of truck ?
The two types I see are, long straight and the other is
a distinctive curve which looks to be taller.
1968 C10 a way to long restoration.
8door is offline   Reply With Quote
Old 09-10-2011, 10:14 AM   #2
Dunenutt
Newbee
Dunenutt's Avatar
Re: What years Automatic shift pointer ?
Tilt pointers are different, because they slide, I believe the others are the same.
Dunenutt is offline   Reply With Quote
Old 09-10-2011, 11:22 AM   #3
Tim Christian
Tim Christian's Avatar
67-70 non tilt column - 71-72 non tilt column - Tilt columns only - So three total. The tilt is totaly diffrent and the other two look a lot a like but the 69-70 is shorter than the 71-72
Tim Christian is offline   Reply With Quote
Old 09-11-2011, 07:53 PM   #4
wylieguy
wylieguy's Avatar
Does anyone make reproductions of the 67-70 ones?
Proud Owner of a 1968 Chevy Truck
wylieguy is offline   Reply With Quote
Old 09-11-2011, 08:11 PM   #5
Tim Christian
Yes just the pointer not the housing or lense.
Old 09-11-2011, 08:26 PM   #6
8door
Like this ? of course more complete with mounting hole.
Old 09-11-2011, 08:37 PM   #7
wylieguy
wylieguy's Avatar
Where do you get them at?
