09-10-2011, 01:27 PM | #1 |
Vintage 4x4s
Dana 60 questions
Do they make gaskets for where the axle plate bolts on the outside of the hub? Thanks,
Jud
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
09-10-2011, 08:50 PM | #2 |
The Older Generation
Re: Dana 60 questions
Jud,
Mine were kind of a metal plate so I just cleaned them up and used the grey gasket sealer on them... Look at this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=474267 LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 09-10-2011 at 08:57 PM. |
09-10-2011, 08:53 PM | #3 |
Yes they do they are bout $4 each and they are the same for the dana 60 and 70.
1978 C10 Silverado Big 10 350/350.. play toy 1990 V1500 Suburban 350/700r4..Daily driver 1987 K10 Silverado 383/400.. Wife's rig WRECKED! 1989 V2500 Suburban 350/400.. SOLD! 1974 C10 Custom10 LWB 350/350.. SOLD! 1974 C10 Custom10 SWB 350/400.. SOLD! 1999 Silverado Z71 LS1.. Wife's rig WRECKED! On the hunt for a new project....... I'm a Chevy guy.....I'm just not a "NEW" Chevy guy. |
09-11-2011, 03:30 PM | #4 |
I got mine from NAPA. They fit no problem.They were made by DANA I believe.
72 C20 Longbed 05 1500 Z71 Last edited by sleepertruck72; 09-11-2011 at 03:51 PM. |
09-11-2011, 04:07 PM | #5 |
They do make them but I've always RTV'd them... never had a problem with them.
09-11-2011, 10:10 PM | #6 |
Vintage 4x4s
Thanks guys, I ended up making a set from gasket paper today. Went pretty fast, traced with a sharpie and cut them out. I have a hollow punch set that puts the holes in. Normally, you probably want a firmer material though with the torque running through the joint but this is just for a trailer conversion i did. Like Locdoc's mine had the aluminum ones on when I took it apart. At first I figured they were spacers to set clearance but after thinking about it they were most likely a gasket capable of keeping the joint tight under the torque exposed to the joint.
Jud
09-12-2011, 07:13 AM | #7 |
I reused my metal ones with copper seal on both sides. Couldn't find any that fit at AutoZone, Napa, Advanced, Oriellys....Didn't want to wait for mail order. No leaks yet, but just sitting in garage with 10 miles since rebuild.
