09-10-2011, 02:12 PM | #1 |
Bolt in transmission tunnel
Are the 4x4 trucks the only ones that got the bolt in tunnel or was it a trans thing auto or 4 speed ???
09-10-2011, 02:17 PM | #2 |
67-72 parts collector,…
Re: Bolt in transmission tunnel
4-speed, 2wd and 4wd trucks had them.
Also TH-400 equipped 2wd trucks had them. (these were usually 402 big block trucks)
09-10-2011, 02:27 PM | #3 |
I am looking for a nice cab mine is ruff and it has a bolt in tunnel all the cabs i am finding do not have the bolt in tunnel
09-10-2011, 02:52 PM | #4 |
The "low hump" cabs can be easily modified to accept the large "bolt-in" hump.
I've done it on two of my trucks.
09-10-2011, 02:56 PM | #5 |
Junior Member
Buy a cab and cut out the area for the tunnel and bolt in the high hump tunnel cover. Will take a little work, but it can be done.
A few weeks ago my son bought a truck that was originally a low hump but the P.O. cut it out and bolted in a high hump cover since he was going to put a BB with a 400 tranny in it for drag racing. Like many projects it never happened so my son got a mostly rust free straight swb '71 for $600.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
09-10-2011, 02:57 PM | #6 |
Junior Member
Man you are fast, you beat me posting, lol.
09-10-2011, 09:53 PM | #7 |
Ok i found i realey nice standard hump cab now i just need figure out how to cut my high hump out of my old cab and put in to the new replacement cab also where is the hidden vin located at on a 70 cab ??
09-10-2011, 09:59 PM | #8 |
just unbolt the high hump cover from the old cab.
a plasma cutter makes quick work of the low hump |
09-10-2011, 10:02 PM | #9 |
Fabricate till you "puke"
Just bolt your high hump pan out, lay it on the floor of the low hump(where it fits), & draw a line....If you cut about an inch inside of that line all around, you should be good to go! as far as the VIN, the only one I know of is riveted to the dr side pillar? crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
09-10-2011, 10:06 PM | #10 |
its all about the +6 inches
