04-11-2003, 01:17 AM | #1 |
Lowered Fender Height Measurement: Is this right??
I finally got my truck all put back together today, and I parked it on a solid slab or cement and I measured it..hmm..came up 28½" in the back (5" drop on 255/55-17) and 32½" (No drop same tires)
Here's a shot: (Since you all ask for pics.) |
04-11-2003, 01:21 AM | #2 |
04-11-2003, 01:22 AM | #3 |
5" drop is only an estimate, it also depends on the springs and the number of springs you have. how did you lower the back of it?
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
04-11-2003, 01:25 AM | #4 |
DJM Flip Kit
04-11-2003, 01:28 AM | #5 |
04-11-2003, 02:01 AM | #6 |
You plan on doing the front. Looks funky with the front up so high.
04-11-2003, 02:06 AM | #7 |
maybe the # of leaves has something to do with it, but i cant see an 1" different.
04-11-2003, 02:10 AM | #8 |
if its not low enough for you put some drop shackles on it to give you another 1 inch or 2 inches depending on the mounting hole you use.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
04-11-2003, 05:18 AM | #9 |
also, you cant base the drop on the measurement you take off the front, the rear of these truck sits higher anyway.
04-11-2003, 01:23 PM | #10 | |
You get what you pay for
Stock shackles are 4" long. My Western Chassis shackles are 5-1/2" at the lower hole and 6-1/2" at the top hole. So we have either 1-1/2" lower or 2-1/2" lower, but only at the rear spring eye. It will only be half this amount at the axle, which is where the actual drop occurs. I wish companies would stop adverstising their shackles as 1 or 2 inch drop. It just ain't so. I guess I'm just being picky.
Mike 1985 Chevy C-10 |
04-11-2003, 01:31 PM | #11 |
Actually, I'm worried the FRONT will be too high...If the fron't lower by an inch, then that's ok
04-11-2003, 01:36 PM | #12 |
Oh, and about the 1" difference in front and rear measusrments. The front fender well lip is higher than the rear one. You can't use the measurements as actual to check for level. If the back measures around 1" to 1.25" lower, it's real close to level.
04-11-2003, 01:41 PM | #13 | |
04-11-2003, 01:45 PM | #14 | |
Mine is as level as it can get, measuring at the pinch weld under the cab/bed. Mine is dropped 4/6 and measures 27.5" up front and 26.25" out back. 1-1/4" difference at fender well lip. |
04-11-2003, 02:32 PM | #15 | |
Signals in the bumper.
Re: Lowered Fender Height Measurement: Is this right??
That thing needs a paint job badly. :p
Jeff C. 1981 Chevrolet Silverado - Under major construction...again. link 1962 Chevrolet Impala 4D Sedan moredoorclassics.com 1936 Ford Pickup - Frame-off in progress link 1979 Chevrolet Camper Special Flatbed link |
04-11-2003, 02:35 PM | #16 | |
Re: Re: Lowered Fender Height Measurement: Is this right??
04-11-2003, 02:41 PM | #17 |
Boy, you sure are on the ball! Quick reponses.
I did mine the opposite of you. I did my paint first, then wheels, then suspension, working on the interior now and I still have yet to do the engine. Next time I will follow your pattern.
04-11-2003, 02:43 PM | #18 | |
Yeah, I would have went paint first too..but I spun #8, so I had no choice BUT to do the motor, and I couldn't even bear the ride (the shocks and bushings were GONE!) so I had to upgrade the suspension, which lead to me having to get smaller wheels (I had 32x11½ 15's) LUNCHTIME! |
