Old 09-10-2011, 03:01 PM   #1
Mikey's68
Radiator Hose Question
I have a 283 located setback to the rear position in my 68. Problem is the standard radiator top hose(24 inch long) is too short to reach. Any suggestions out there or apps that might work on my setup? Thanks Guys
Mikey's68 is offline   Reply With Quote
Old 09-10-2011, 05:21 PM   #2
landsurvey1
landsurvey1's Avatar
Re: Radiator Hose Question
Try a website called coolflex.com. I have the red hoses on mine and it looks pretty sharp. Life time warranty and you can cut them to fit. Longest top radiator hose is 3 ft I think.
landsurvey1 is offline   Reply With Quote
Old 09-10-2011, 05:24 PM   #3
Mikey's68
Thanks! I look them up!
Old 09-10-2011, 08:32 PM   #4
rsavage
rsavage's Avatar
You might want to use a 4X4 set up which has a metal pipe and two shorter straight hoses for the end.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 09-10-2011, 10:22 PM   #5
Andy4639
Old member
Andy4639's Avatar
Cool Re: Radiator Hose Question
Do like me make a line out of aluminuim and cut a old hose up to mount with.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-11-2011, 12:44 AM   #6
Mikey's68
That's something i would of never thought of! Great idea! Thanks
Old 09-11-2011, 12:45 AM   #7
Mikey's68
Thanks alot!
Old 09-11-2011, 01:24 AM   #8
FLEET72
FLEET72's Avatar
'72 with a 350. My motor is mounted to the rear as well so I know it works.
I like the look of Andy's better though.
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
Old 09-12-2011, 11:40 PM   #9
Mikey's68
My problem is i have the oil filler tube (which i want to keep) in front and the water neck is facing forward towards the radiator!
Old 09-13-2011, 12:19 AM   #10
Andy4639
Old member
Andy4639's Avatar
Go buy a swevil TPI one. They move the connection off to the side.
Old 09-13-2011, 07:32 AM   #11
OJ1988
Just a car guy
OJ1988's Avatar
See my 250-350 swap thread.
I used an upper hose for a 76 chevelle.
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
