09-10-2011, 03:11 PM | #1 |
Fan Shroud for my 56
Anybody know if there are aftermarket shrouds for these trucks? I will make one if I have to, but figured I would see if there were any out there.
http://community.webshots.com/user/56myway |
09-10-2011, 09:04 PM | #2 |
Yellow truck club
Re: Fan Shroud for my 56
there are some plastic shrouds out here. I used one in my 59 and it worked well
................................................................ Brian ...... My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW 59 Chev Apache PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited Last edited by entourageguy; 09-11-2011 at 09:11 PM. |
09-11-2011, 02:59 AM | #3 |
In mid 80's I pulled one off of a late 70's gm car and modified it to work. My rad is in the 6 cylinder position so fan to rad clearance is about 5 inches. Radiator is a big truck unit, 1" thicker and a little deeper than small trucks.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
09-12-2011, 01:00 AM | #4 |
i do have an ''original '' steel shroud i was useing on my 57 w/an original radiator - but i have changed things around and it is not being used .
09-12-2011, 01:17 AM | #5 |
My truck was (I'm fairly sure) originally a 6 cylinder and sometime later a 283 was installed. When I bought it a few months ago it had no shroud at all but I found this one at The Car and Truck Shop, Orange, CA:
http://www.truckandcarshop.com/trucks47_59/t47_071.html With minor modifications and a different fan spacer it fits fine for a driver that is: Hope these help. |
09-12-2011, 07:55 AM | #6 | |
don't mean to hijack your thread but I'm in the same boat looking for a fan and shroud. Dan, my truck is an original V8 truck so I only have about 3 inches between pulley and radiator. So maybe no spacer for me? How much work did it take to get the shroud to work? thanks.
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
09-12-2011, 10:29 AM | #7 |
Some mods were required but nothing complex at all. It's plastic so cutting it is easy. There are no holes in the mounting flange so you just drill some to coincide with the radiator mounting holes. My mechanic told me the fan blades should only extend 1/3 to 1/2 their width into the shroud for maximum "draw" or pulling of air. My original fan spacer was too long. The one you see is SHORTER than the original
Posted via Mobile Device |
09-12-2011, 10:36 AM | #8 |
how big of a fan did you go with? I see the link you sent has a 6-blade in 17 and 18 inch.
09-12-2011, 12:48 PM | #9 |
fwiw my fan is an 18" aftermarket steel/ss blade unit. In needed a 1" spacer to get the fan located in the center of the "hour glass" venturi portion of the shroud.
09-12-2011, 01:05 PM | #10 | |
like i said above, i've got prolly less than 3" between my (WP) pulley a the face of the radiator. Guess I'll have to get a fan and shroud then determine how big a spacer, if any, is needed to get my blades located properly in the shroud. Do you recall where you purchased your fan from?
