Headers
Can you use full length headers with a 4/6 drop. I have the Hedman Elite headers and they are not fitting very good. There is no since of using them if I cant reuse them when I lower it. Any suggestions
Re: Headers
I have the same headers, I don't think will work with a 4-6 drop.
I'm not as good as I once was, But I'm as good once as I ever was. |
Fabricate till you "puke"
Re: Headers
I agree, I dont think the hedmans will work, the dr side is pointed downward& that will be the issue. I swapped my hedmans, for a set of Hooker comps (#2452). My old truck has a 2 1/2-3" drop on the nose, & about 5" rear. The very bottom edge of the collector hangs (at the flange), about 2" under the rails.....I could dump the nose another 1/ 1/2", & I doubt that it would cause any trouble. just make sure that the rest of the exhaust is tucked up tight. best of fun,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
