09-10-2011, 09:56 PM | #1 |
What manual transmission yall running
I have a 69 with a 327 finally got to drive it more than just around the back yard today
Super excited about that but found out the clutch is slipping. It has a manual 3 speed in it I want 2 upgrade to a 4 speed so now its the time to do it But I dont no what will work ? What do yall suggest? Thanks Posted via Mobile Device |
09-10-2011, 10:06 PM | #2 |
Fabricate till you "puke"
Re: What manual transmission yall running
Im running a 6 spd ROD in my longhorn(fun, but expensive)! crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
09-10-2011, 10:07 PM | #3 |
Grandpa in the rustmobile...
3spd on the column wth new bushings and new cluthc
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
09-10-2011, 10:11 PM | #4 |
What?
Sm-465
Chris 1968 K20 Suburban 1972 K10 LWB PU |
09-10-2011, 10:17 PM | #5 |
Runnin a new M-22 Rockcrusher built by Bob at Fourgears in the Chicago area.
Then had to put an Eaton Posi in the rear. Fun stuff! |
09-10-2011, 10:22 PM | #6 |
I'm drivin the old Muncie 3spd with the non-syncro first gear. There is a good thread around here that shows how to install a T5. I quickly read over it and may revisit it later. I like the Camaro trans but I'd rather have the S10 shifter position. I didn't look hard enough to see if the S10 shifter setup can go on the Camaro transmission.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
09-10-2011, 10:30 PM | #7 | |
--Do you want to go fast ....or will it be a working type truck, that carry's or pulls heavy loads ? --Do you want to do a combination of both? --What is your budget ? |
09-10-2011, 10:47 PM | #8 |
My 68 has a three speed saginaw.
Keith |
09-10-2011, 11:11 PM | #9 | |
Id like something good for crusing around town maybe a little highway id like a 4speed My budget is not big with 3 kids Posted via Mobile Device |
09-10-2011, 11:11 PM | #10 |
NV4500 5 speed overdrive
My 1972 Blazer 5.3 E85/ NV4500 5spd 4x4 Work in Progress http://67-72chevytrucks.com/vboard/s...d.php?t=291482 ****SOLD!!!!!**** 1965 GMC 4X4 http://67-72chevytrucks.com/vboard/s...d.php?t=294727 |
09-10-2011, 11:19 PM | #11 |
Junior Member
I grew up driving trucks with the SM-420 and SM-465 so those are the ones I have. The SM-420 is behind a L6 and the SM-465 is behind a 454.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
09-10-2011, 11:51 PM | #12 |
The SM465 is what I have - the true classic truck tranny. Fun to drive, impossible to break.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
09-10-2011, 11:58 PM | #13 | |
If your set on a four speed there's .... --Borg-Warner T10....now built new by Richmond --Muncie M20 M21 M22 --Sm (Saginaw-Muncie) car --Sm (Saginaw-Muncie) truck.....sm465 ,sm420....these are called granny gear four speeds due to the extra low stump pulling 1st gear. Great for hauling, towing and off road, but not acceleration . I had 1 in my dually and swapped it out for a built automatic. --New Process "truck"...very much like above --The first 2 are expensive ....and more performance oriented than you really need --The truck granny 4 speeds are super tough...can still find good used one's .....I've got a sm465 in my driveway will sell cheap... --none of the above have overdrive...4th gear on all is 1:1...that's the main problem, so...... --Here's the best bang for the buck ...I'd go with a Tremec T5 (5 speed)...easy to find, came in Camaro's, S10's and some other Gm cars and trucks. These are not the strongest transmissions out there, but there strong enough for a stock to mildly built small block. And here's the best part .....you'll have a true overdrive trans. and gas at $4.00+ a gallon you will appreciate that 5th gear. IMHO Last edited by RUSHNBOBO; 09-11-2011 at 12:05 AM. Reason: added line |
09-11-2011, 01:25 AM | #14 |
I'm running a sm465, old, clunky, not the smoothest but that think sure is tough.
1969 Chevy c20(Miss Hackjob) |
09-11-2011, 11:00 AM | #15 |
Cool Truck
I've got a T5 from an 83 Camaro
1968 Chevrolet C20 Longhorn "Cool Truck" 1937 Chevrolet Pickup - Project Looking for a patina'd 68 50th Anniversary longbed |
09-11-2011, 12:58 PM | #16 |
Just a car guy
M-20 wide ratio in place of stock 3 speed.
Hurst competition plus shifter. Posted via Mobile Device
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
09-11-2011, 03:42 PM | #17 |
Sheetmetal Psycho
T10 4spd from a early 80's camaro. Would recommend the 5 speed if you intend on driving distances.
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up! Project "Rigginstine's Monster" 1971 C-10 longbed 355/4spd Future mods: 67 front clip Webby's Rigginations - where everything has potential! |
09-11-2011, 04:26 PM | #18 |
09-11-2011, 04:40 PM | #19 |
I put the T-5 in every truck I do. The T-5 is easy & cheap to convert. You get the advantage of the o-drive. Like the guys say they are not real stout but if you dont go doing burnouts or speed shifts they will stand up.
Yes you can put the S-10 tail houseing & shifter on a Camero trans. The Camero version is a little stronger & has closer gears. |
09-11-2011, 08:10 PM | #20 |
NP 435. 190000 miles, still shifting good!
09-11-2011, 09:17 PM | #21 |
sm420, definatly drives like a truck!
'67 GMC C20 lwb built it on a high schooler's budget 15years ago. Slowly rebuilding it on a working man's budget now. |
09-12-2011, 12:41 PM | #22 | |
This sounds like what I will look into does it require any mods or will bolt rite up? What about the shifter should it line up where the hole is in the floor ok? Posted via Mobile Device |
09-12-2011, 12:46 PM | #23 |
Tremec TKO 5 speed (not the T-5). Been in the truck 6 years now.
09-12-2011, 03:03 PM | #24 | |
Cool Truck
09-12-2011, 03:41 PM | #25 |
SM-465. Tough and reliable
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
