Old 09-11-2011, 11:11 AM   #1
buddylee
68 c20 to c10
ok. newbie here.
just got my 68 c20 yesterday.it is 8 lug all round with trailing arms. my plan is a 5 lug disc swap on front and 5 lug rear. if i find a donor truck from 73-87, is the rear going to be the exact width?
do i cut the perches off of the existing rear or do they sell aftermarket perches for the new rear end?
what rear is in truck now? huge pumpkin. any value?
buddylee is offline   Reply With Quote
Old 09-11-2011, 11:19 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 68 c20 to c10
ECE (www.earlyclassic.com) sells new spring perches so you can install a 73-87 rearend.
You will also need a Super Track Bar so you can center the rearend.
(the 73-87 housing will not have an attachment point for the track bar)
ECE also sells a conversion spindle that will be a direct bolt in for your C20 ball joints and outer tie rods.
These spindles allow to you install C10 rotors and calipers.
These make switching to 5-lug up front super simple.
So really all you need is a rearend.
71-72 would be a bolt in 5-lug.
Really no need to find a donor truck. Ha.
Keith
Convert to disc brakes.
Old 09-11-2011, 11:23 AM   #3
buddylee
Re: 68 c20 to c10
thanks. is that monster rear end w 8 lugs of any value?
Old 09-11-2011, 01:26 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 68 c20 to c10
To the right person, yes. I suggest putting it on Craigslist and see if it will sell.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
