09-11-2011, 01:20 PM | #1 |
71 Lower control arms
What options are there to replace a set of lower control arms with a drop spindle? I would like a bolt in deal with the shafts already in place
I was going to reuse the originals, but the threads where the bushings go are pooched. Thanks, Pat |
09-11-2011, 06:01 PM | #2 |
Re: 71 Lower control arms
Me too....threads are toast on both uppers and lowers on mine. New ones from Jegs or similiar aren't too bad price wise.....
70chevytruck |
09-11-2011, 06:37 PM | #3 |
Find me a better price than $1450! ouch!!!
09-12-2011, 12:35 AM | #4 |
$1450? For what/where?
09-12-2011, 06:47 AM | #5 |
Control arms set up for airbags, coil spring or coils overs..
Posted via Mobile Device |
09-12-2011, 02:23 PM | #6 |
Lower control arms for springs.
09-12-2011, 02:26 PM | #7 |
09-12-2011, 02:31 PM | #8 |
67-72 parts collector,…
Switch to a set of 73-87 control arms.
They have press in rubber bushings. Should be plentiful in junk yards or Craigslist. Might even be some in our classifieds section.
09-12-2011, 02:33 PM | #9 |
Are they a direct bolt in or do I need more parts to make it work, like sway bar, etc?
09-12-2011, 02:41 PM | #10 | |
The 73-87 arms take a slightly larger u-bolt to hold them to the crossmember saddles. (9/16" vs 1/2" I think). That's what drills are for.
09-12-2011, 04:04 PM | #11 |
Technically, you can still use the smaller u-bolts. The ID of the u-bolt where it fits the control arm shaft is the same. The diameter of the actual u-bolt is larger for post-73 suspensions (9/16 vs 1/2").
09-12-2011, 08:25 PM | #12 |
CPP lowers ordered from Scott's Hotrods (Justin)
It's way eaiser to buy this stuff from the States than locating up here in northern Alberta. |
09-13-2011, 08:43 AM | #13 |
70chevytruck |
