Old 09-11-2011, 03:39 PM   #1
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Power steering
Ok guys,I need to do the PS upgrade NOW.I went from having 3 or so inches of play to almost half a trun of the steering wheel in a 15 mile cruise last night. I have everthing to do the swap except the pitman arm.I don't know what year the gearbox is from,but it does have the o-ring style fittings.I haven't been able to find a cross reference to determine which pitman arm to order(you know they aren't in stock).The only #'s I find on the PS gearbox are 4L and on the adjustment cover 2A090.Does anyone know where to find out what box I have so I can order a Pitman arm?
Thanx for any help.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-11-2011, 05:05 PM   #2
treveiger
treveiger's Avatar
Re: Power steering
The o ring fittings started in early 80s so id start with that, the way I understand it the 2wds can switch pitman arms with 2wds an same goes with the 4wds but 4wd can't switch with 2wd. Hopefully someone else would chime in also.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 09-11-2011, 05:44 PM   #3
Tim Christian
Tim Christian's Avatar
Re: Power steering
Deland. You should be able to get one for a 68-70 with powersteering should work on the gearbox
Tim Christian is offline   Reply With Quote
Old 09-11-2011, 06:24 PM   #4
PanelDeland
Re: Power steering
Thanx Tim & treveinger.You guys help a lot.I knew I read somewhere that any Pitman for a PS box would fit any of them but I saw several Part#'s for the different years.I knew it would probably fit the center link but I wasn't sure about the box.Thanx again.
Old 09-11-2011, 06:38 PM   #5
Tim Christian
Re: Power steering
Just remember 67 did not have that style power steering and 71-up center links are different.
