Old 09-11-2011, 06:40 PM   #1
c10hevy
c10hevy's Avatar
2 bolts to hold a brake booster??
I got back from the local yard today with a 1987 r/k20 3/4ton brake booster (Disc/Drum) I noticed that the middle hole line up exactly with the original holes from my Dum/Drum non-power master cylinder. Is 2 holes enough to hold the booster/MC or should I drill out the other four and use all 6?
c10hevy is offline   Reply With Quote
Old 09-11-2011, 09:01 PM   #2
tooslo60
tooslo60's Avatar
Re: 2 bolts to hold a brake booster??
I'm using that same booster, and I used all 6 bolts. I wouldn't trust only 2.
Andy
tooslo60 is offline   Reply With Quote
Old 09-11-2011, 10:29 PM   #3
k1rodeoboater
yup bolt up at least 4...I wouldn't trust two. If you don't want to drill holes for the other bolts get a new booster and CPT Fab's bracket.
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201
no garage, no shop, limited storage space and tools....no problem.
k1rodeoboater is offline   Reply With Quote
Old 09-11-2011, 10:54 PM   #4
tooslo60
tooslo60's Avatar
If you're only gonna use 4 bolts drill the top 2, they're a whole lot easier to acess than the bottom 2.
Andy
