Old 09-11-2011, 08:29 PM   #1
71C10Matt
71C10Matt's Avatar
lowering a 71lwb C10?
Ok i have a 71 lwb. im going to bag it. i will be using drop spindels up front. my plans r to go as low as posable with out body droping it. so my ? is with the two pice dline will i have to change out the carer bearing crossmember? or do anything to the dline? what to do to the exhaust too? witch route should i go???? hope u all can help thanks........
71C10Matt is offline   Reply With Quote
Old 09-13-2011, 02:46 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: lowering a 71lwb C10?
Check out Porterbuilt Farication.
http://www.porterbuiltfabrication.co...olet-Truck-249
They sell a cool tubular trailing arm crossmember that allows the exhaust to pass thru.
Plus you can switch to a heavier duty carrier bearing.
Keith
Convert to disc brakes.
