Old 09-11-2011, 08:46 PM   #1
Larry1
402 bb motor
I bought a 402bb motor to put in my 70 gmc shortbox and was wondering if it would bolt up to my 3 speed manual transmission.
Larry1 is offline   Reply With Quote
Old 09-11-2011, 08:58 PM   #2
hotrod farm truck
hotrod farm truck's Avatar
Re: 402 bb motor
shouldn't be a problem if its a chevy 3 speed transmission.
hotrod farm truck is offline   Reply With Quote
Old 09-11-2011, 09:05 PM   #3
Larry1
Re: 402 bb motor
so i dont have to change clutch or anything
Old 09-11-2011, 09:24 PM   #4
hugger6933
Re: 402 bb motor
The clutch might work but the flywheel won't. When you get a flywheel make sure it is for the 396-402[or whatever] the 396 -402's had a different method of balancing and the flywheel for a 454 will make your motor vibrate and then eat itself from the inside.
hugger6933 is offline   Reply With Quote
Old 09-11-2011, 09:29 PM   #5
Larry1
Re: 402 bb motor
I have the fly wheel that came with the 402,so guess i will give it try
Old 09-11-2011, 09:44 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 402 bb motor
As long as it is a flywheel and not a flex plate for an automatic, then you should be golden.
You may want to step up to a larger clutch, but in reality I know little to nothing about that.
A question that has not meen asked yet, but would probably be coming up soon anyways, the low hump floor in your truck should be perfectly fine if you set the 402 up like original. The big block/3 speed trucks came with low hump floors.
