09-11-2011, 11:15 PM | #1 |
Front coil 4inch drop help.
I got a Set of 6 inch drop coils from ece.. And i want to cut the Front so i get a 4 inch drop... How many coils do i cut to do this ? And can i just cut the fronts only or do i need to get drop spindles? And cut them? Thanx for the help.
Posted via Mobile Device |
09-11-2011, 11:23 PM | #2 |
Re: Front coil 4inch drop help.
1 1/2" drop spindles and 1 round off the coil should equate to approx. 4" - 4 1/2" ... it's not recommended to cut more than 1 full round off the front coils.
09-11-2011, 11:43 PM | #3 |
10/30/19
I cut 2 coils on my 72 about 4 or 5 years ago. It'll hit the bump stops on big dips in the road.
Fight the good fight, finish the race, keep the faith |
09-12-2011, 12:40 AM | #4 | |
I don't/wouldn't recommend cutting more than 1-coil off. The spring doesn't have enough 'rate' to support the truck @ the shorter height so you bottom out much easier. You can also run into an un-safe situation if the suspension becomes unloaded as the shorter coil can easily fall out of place (like on a big dip @ highway speeds).
09-12-2011, 10:28 AM | #5 |
Doh!
