Old 09-12-2011, 11:08 AM   #1
JORGIE95961
limited tool options
Hey folks!! I’ve been working on my 71 Chevy SWB since February... Started off as a SWB GMC and a long bed Cheyenne.. I am in the process of doing body work at the moment. I am very limited as I do not own a compressor or air tools.. I have some buddies with big ones at home. Since I don’t have a lot of time I usually go up and straighten out a little metal at a time... The problem is I need to prime these spots.. I’m getting really close to buying what they call automotive primer in a can and later on spraying some high build over it... So this a total no-no?
JORGIE95961 is offline   Reply With Quote
Old 09-12-2011, 11:23 AM   #2
cdowns
cdowns's Avatar
Re: limited tool options
tho not the best it is a heck of alot better and alot more protection than nuttin
Old 09-12-2011, 12:57 PM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Protect it as well as you can from the moisture in the air.....primer may absorb it.
Member Nr. 2770
Old 09-12-2011, 01:03 PM   #4
JORGIE95961
rEALLY PRIMER ABSORBS MOISTURE? I HAD NO IDEA.. THEY WHY DO WE USE PRIMER FOR... WOWSERS
Old 09-12-2011, 01:28 PM   #5
MVHandy
Primer is relatively porous and does not provide protection. It is intended to promote bonding between the substrate material and the topcoat.
MVHandy is offline   Reply With Quote
Old 09-12-2011, 01:32 PM   #6
JORGIE95961
whoops.. i used to drive around inprimmered chevys all the time as a kid. and here i thought id at leat keep it from rusting./. so it doesnt work at all for that huh
