Old 09-12-2011, 12:59 PM   #1
darkone
Rear Wheel Wells; Foam Tape For Vibration? Also need help installing heater core
First question:
do i need to use a foam tape on the back sides of the wheel wells where it attaches to the bed? It looked like there was something there at one time when I striped everything. What is an ideal product to use as normal home depot foam tape may hold water.
Second question:
When installing the heater core, do i need to use an adhesion product of some sort to hold the heater core in place? it seems as though it will just be flopping around as it stands now.
any help appreciated. thanks!
darkone is offline   Reply With Quote
Old 09-12-2011, 01:17 PM   #2
danleaman
Re: Rear Wheel Wells; Foam Tape For Vibration? Also need help installing heater core
I would think that foam tape would hold water, but I am no expert on that kind of stuff. As for the heater core, I have a 72, ac truck and there are Removable brackets that hold the heater core in position.
Dan
danleaman is offline   Reply With Quote
Old 09-12-2011, 01:23 PM   #3
dmack91
dmack91's Avatar
My 68 is a non-AC truck. The heater core was held in by two u-shaped brackets that were threaded on each end to secure it.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 09-12-2011, 06:08 PM   #4
darkone
thanks for the help guys, ill grab one tomorrow. still looking for help on mounting the rear wheel wells on a stepside
Old 09-12-2011, 06:53 PM   #5
john
member #16
john's Avatar
I've used strip caulk with good results. It is pliable and seals cracks.
http://www.google.com/#q=3M%E2%84%A2...w=1536&bih=710
john is offline   Reply With Quote
Old 09-12-2011, 11:29 PM   #6
darkone
youre the man, thanks john. is this a body-shop product? or home depot?
