Old 09-12-2011, 03:26 PM   #1
Goldfinger
Goldfinger's Avatar
urgent 700r4 problems
I haven't used drive in a while and today i use it and it will not shift past 2nd gear, it begins to vibrate violently at 60. when i put in a new carb the end of last year i kinda jerry-rigged a way to put the tv cable on so i doubt its in the right geometry but is this causing it or is it more serious? Overdrive goes through all gears fine.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 09-12-2011, 03:58 PM   #2
Goldfinger
Goldfinger's Avatar
Re: urgent 700r4 problems
It seems to be tv related
Old 09-12-2011, 05:39 PM   #3
79k30dually
The TV cable is the transmissions only link to the engine. If it's not correct it will damage the trans. "bowtie overdrives" has a couple execelent articles on operation and adjusting The TV cable. Good luck, Ron.
79k30dually is offline   Reply With Quote
Old 09-12-2011, 09:58 PM   #4
Goldfinger
Goldfinger's Avatar
thanks. i'm getting the correct mounting bracket tommorow
