09-12-2011, 08:51 PM | #1 |
subframe or s-10 swap? Advice needed.
Bought a 55 first series in 09 and did a quick minor restore on it. Fixed rust in cab, basic flat black paint job. Rebuilt the doors, re-did the interior just basic stock stuff. Put headers on the 235 and re-did the bed. Front king-pins replaced.
Drives nice, but am eager for a winter project. I want something that I can put a 454 in and tow a trailer with. I have seen the subframe articles and that is very intriguing. I have also seen the s-10 threads and realize that is also an option. I am leaning towards the front subframe but am open for opinions and recommendations. What exactly should I be looking for in a front subframe if I go that way? I have good tools/shop/skills but just am eager to pick your brains as to not learn the hard way.
Smile at challenges, curse at idleness. 1955 chevy 3100 1st series Self-built twin 454 front engine dragster 1999 corvette convertible 1984 chevy blazer |
09-12-2011, 10:14 PM | #2 |
AD Addict
Re: subframe or s-10 swap? Advice needed.
I did an S10 with a '54.
Here's my HAMB thread: http://www.jalopyjournal.com/forum/s...d.php?t=137385 Would I do it again? Yep. I start tomorrow. What motor? Maybe a 396. We have one... I'm using the same set up. X cab frame shortened 5". Wider rear end. Got a disc brake set up with about 62" width via friend of my son. I'll clean it up, run the brake lines and exhaust without the cab on then go for it. It is already boxed so it should handle a mild BBC. |
09-13-2011, 09:50 AM | #3 |
i started to do the subframe, but quickly changed my mind and went the s10 route. for me, the s10 way has been easier AND i prefer the idea of a non-cut frame rather than a grafted one. but thats just me. another reason i went s10 is i want to bag it and bagging an s10 can be done pretty easily and not break the bank....too much
AND the s10 frame if definatley a bit sturdier than the stock AD frame. i'm not saying the stock is weak by any means (if you box it) I know a guy whos into racing S10s (amature not pro) and he's got one pushing 700+hp with stock s10 frame and no issues. Although i will say lining up the front fenders, hood, & grill is kinda a pain in the but on the s10, but you'll be fighting that with the front clip as well.
"When in Rome we shall do as the Romans,...when in Hell we do shots at the bar." |
09-13-2011, 09:53 AM | #4 |
Oh, and as for the subframe....don't run the camaro clip. they're too wide. the g-body clips are better (from what i've read and messed with)
09-13-2011, 10:49 AM | #5 | |
sells narrower tubular A arms. |
09-13-2011, 01:13 PM | #6 | |
09-13-2011, 05:10 PM | #7 | |
09-13-2011, 05:45 PM | #8 |
No really the s10 is a good way to go but they look too narrow to me. but if you like the huge wheels narrow good. i don't like them that much. just my opinion.
AS for turning radius I just checked mine with a 75 camaro clip and it could go 2" on a side without rubbing. |
09-14-2011, 04:25 AM | #9 |
A 454...hmm S-10 or stock with clip. How good are your welding skills and is your shop floor dead level? I would look into a whole new frame from Morrison or one of the others. That way you can order it exactly the way you want it. Have a desire to go wider or your tires? Plan to race it once in a while? The stock frame would need full boxing, the S-10 frame can handle a small block but wasn't meant for a BBC. If you don't mind welding up your own headers for the BBC go for it. With the kit you can use any front or rear suspension your budget allows for. Also you can order any amount of drop you want without bagging it or using drop springs, a-arms or blocks.
09-14-2011, 08:41 AM | #10 |
S10s can be had plenty cheap. i picked up a runner for 500. sold off parts and MADE back my 500 + 35 and ive still got parts i can sell. so i'm UP and have all the parts i need. and yea, the narrow front isn't for all. that can also be fixed with the right wheels (like some chrome reverse wheels )
the S10 frame can handle a big block just fine. sure you may want to do some boxing for peice of mind, but it will handle it just fine. certainly just as good as the stock frame. BUT, that being said, stuffing a BBC on an s10 frame under a AD-truck body would be a task by itself. it can be done, ive seen it. i wouldn't want to tackle it tho. haha. BigDan is right about welding skills and leveling up everything. i clipped my origianl frame (g-body). my welding skills are decent and getting everything square was a task. i just wasn't happy with the clip and really got interested in the frame swap AND i found areas on my original frame that were rusted/tweaked/toast. But my motivation for the frame swap is based more on a low ride height and than HP. I will run a healthy SBC/700r4. either way, have fun with it and learn. Chris
09-14-2011, 08:43 AM | #11 |
mknittle, just realized you said S10s were expensive where you live. i thought you meant across the board. sorry about that.
09-14-2011, 10:07 AM | #12 | |
I think what keeps the price up On S10s here is there are so many landscape maintenance people. I think If I were to restart mine I would just build a frame. The s10 is a great frame swap for most people.I just always do things the hard way. |
09-14-2011, 10:19 AM | #13 | |
09-14-2011, 10:39 AM | #14 | |
09-14-2011, 10:45 AM | #15 | |
09-14-2011, 11:51 AM | #16 |
Moderator
This is one of those neverending discussions. I don't think there are any bad choices as long as your workmanship is good. I chose to go with a Mustang 2 by TCI mainly because I wanted airbags. Otherwise I would have considered a nova clip. S-10 frame has it's merits too, but just is not my thing.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
09-14-2011, 12:26 PM | #17 | |
Certified Car Nut
I say do your research (like you are doing) and do what you are comfortable with. Just make sure what ever route you choose it is safe. |
09-14-2011, 03:49 PM | #18 |
If there's one person on this forum I would follow their advice it would be "The Truck Whisperer" He's done it and he's fixed some BIG mistakes other people have made. When he gets done with a frontend it will be safe and DONE RIGHT!!!
09-14-2011, 03:51 PM | #19 | |
09-14-2011, 06:22 PM | #20 | |
Certified Car Nut
Yeah you got that right, thats why I like this forum so much. Its fun looking at others projects and sharing information. The well wishes are priceless and very motivating. |
09-14-2011, 06:36 PM | #21 |
[QUOTE=Kabwe;4899526]How can I find this "The Truck Whisperer" you speak of?
You don't have to look very hard or far-He goes by Kabwe. Honestly I feel your ability to correct some very bad jobs is great |
09-14-2011, 06:53 PM | #22 |
Certified Car Nut
Thank you very much and your compliments are truly appreciated but I'm a long way from the truck whisperer. There are a lot of amazingly talented guys on this forum and to think a lot of them are home builders is just mind blowing and inspirational. I'm a huge fan of the home builders.
