Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 09-12-2011, 11:20 PM   #1
lyrikz
PITbut
lyrikz's Avatar
Building stereo box. How to do curve?
Steroe box is going to look something like this.
How would i get the curve. I was going to build a box in the middle, and then use some type of flexible material for the corners i just dont want them to rattle when the bass hits.
Any suggestions?
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 09-12-2011, 11:25 PM   #2
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
Re: Building stereo box. How to do curve?
Fiberglass.
ProStreet68SB is offline   Reply With Quote
Old 09-13-2011, 01:01 PM   #3
tubbedII
needs more $$$
tubbedII's Avatar
Originally Posted by ProStreet68SB View Post
Fiberglass.
Yup...do as your saying and build the box, but leave room for a fiberglass cover. Then build the cover using fiberglass. Use something flexible as the base and then fiberglass to reinforce it and hold the shape.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 09-13-2011, 01:04 PM   #4
lyrikz
PITbut
lyrikz's Avatar
Im not sure if i can make that WHOLE fiberglass piece in one piece ya know??
i will get the seat out and start planning something. never used fiberglass so why not give it a shot.
and sold.
Old 09-14-2011, 12:53 PM   #5
jimmydean
jimmydean's Avatar
Just make the corner curve out of glass and the rest out of wood. If I ever get mine done, it will make sense. Mine will look similar, only with more curves.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 09-22-2011, 02:17 PM   #6
AceX
>130dB Moderator
AceX's Avatar
In most fiberglass boxes there is a wooden base structure and several smaller forming structures such as speaker rings. Fleece is streteched over the entire piece, then resin is soaked into the fleece.
Don't make it all one single piece. Make the center your largest piece, then each curve it's own piece. Otherwise, it will be a PITA to get it to fit into the cab, plus it allows you to add better anchor points for the box, and you can hide batteries (like I did) behind the panels.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 09-22-2011, 02:20 PM   #7
lyrikz
PITbut
lyrikz's Avatar
IM only running one battery.. I have an idea. The center box is close to being painted. Then im going to take some dowels and and make a frame for the curve next to the box, then wrapping that and fiberglassing.
The center is fiberglassed. This stuff is REALLY fun.
and sold.
Old 09-23-2011, 12:49 PM   #8
jimmydean
jimmydean's Avatar
That should work great. I started playing with fiberglass when I first started in show stereos back in '88. You can do so much with it, it's incredible. Hell, just look at the kick panels and tweeter pods I made for mine.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
