Old 09-12-2011, 11:52 PM   #1
scotts72heavyhalf
scotts72heavyhalf's Avatar
Thumbs down Lowering question for my 69 C10
I just bought a new project 69 C10 and it has the drop spindle kit and disc brake upgrade, 2.4 spindle and 1.5 coil drop in the front, and a 7" in the rear for a 5/7 drop is what I was told. The problem is the front tires hit the inner fender wells when I hit a dip, how can this be avioded? And the rear bump stops have been removed from the frame. I guess this is common practice? I love the look but I would like to improve the ride. Any suggestions from the experts would be great.
Scotts72C10
scotts72heavyhalf is offline   Reply With Quote
Old 09-13-2011, 09:37 AM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Lowering question for my 69 C10
Was the rear frame C notched? what size wheels/tires you running?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-13-2011, 02:41 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Remove the inner fenders or get shorter front tires.
Keith
Convert to disc brakes.
Old 09-14-2011, 12:33 AM   #4
scotts72heavyhalf
No c-notch but the rear is fine and not rubbing. Running 275/45 R20 all around, I`m replaceing the front shocks, they were shot completly shot and new shorter bump stops in the rear, now there are none and we will see if that helps. I heard there was some company making a taller inner fender well? Any one heard of that.
Thanks for the replys
Scotts72C10
Old 09-14-2011, 01:01 AM   #5
lolife99
lolife99's Avatar
Look here:
http://67-72chevytrucks.com/vboard/s...d.php?t=476769
But they won't work with stock hood hinges.
You'll have to use a set of Porterbuilt Hood Hinges:
http://www.porterbuiltfabrication.co...tarting-at-265
Keith
