short in horn in 85
i took my truck in to the shop didnt have the time to fix a bad bearin column. so i told my mechanic to fix colum, and see about fixing the horn because it was just on a push button. well come to find out he replaced the horn parts but still nothing. theres a short some where cause when you put in a fuse in the horn slot it bursts the fuse! any ideas or test i could do
Robert Olson Transport
![]() Join Date: Oct 2002
Re: short in horn in 85
you gotta trace the wires back from the horn itself. there is somewhere where a power is touching a ground. You can first unplug the horn itself and replace the fuse and see what happens but if there is a pushbutton to that h orn chances are the horn is good , and make sure that there is in fact only one horn or that both horns are plugged into your pushbutton . if the fuse says good its prolly the horn otherwise take an inlne fuse and length of wire and connect that to the interior part of the fuse panel to the unplugged horn and see what happens. This will eliminate the area from the column to the fuse box as a source for the short there, If that doesnt yield results, you need to go through the wiring in the area between the fusebox and the column..with a test light and lastly if the thing doesnt work you need to figure out whats wrong in the column
thanks for the help ill try messing with the thing tomorrow
Anyone here happen to know where the grounds are for the horn on these trucks?
Sell it before it's finished
Did you get it fixed? Having an issue blowing the same fuse.
Brian |
Sadly I spen a while tracing the wire and no such luck on fining a wire touching a ground. From what I was told sense mines an 85 k10. The dome curtassy lights cigarette glovebox are all connected. I opened up the dome light I thought I found the problem. The positive and negative wires had melted together. I then fixed that problem and then insured that run of wire was good the rest of the way. Next I went sill plate to fuse block. Looks fine to me. Then I went to the cig lighter I think I found the problem there. Do the cigarette lighters go out? Causing a short? It has to be either that or some where in the column.
This is another post I did and I followed the guys advise. Question is the Orange wire from the dome does it connect to the back of the block or the top that's how mine looks like it's hooked up. Who know i probably had to separate electrical problems on the same curcit.
Thanks. I'm going to pull it apart tonight.
A place you might also check is the courtesy light switches in the door jams as those I know are a known problem for our trucks
#10 | |
The wire for the cigarette lighter housing was grounding against the ash tray.
Od I don't recall mine being grounded to my ash tray. Could please post a picture of yours maybe it will help me Out
#13 |
Its not supposed to be grounded. That is what was causing the fuse to blow. It had come off of the housing and was resting against the ashtray.
#14 |
alright well on my truck I needed to Change my battery terminal cables, while doing this I ran a new wire from the battery to my CD player. Well I thought I'd see if my cigar lighter was being grounded out like I thought it was. Well I ran a pig tail from my cigar lighter to the hot wire I ran as soon as I did that they sparked.
this was a sigh of relief think that I found part of my problem on my truck. Now sense there's no more light out and I can't work on my truck I'm hoping I found the only problem as to why my horn,cigar, dome and curtassy lights aren't working.
#15 |
It's almost always something simple like that.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint "Cool ain't ever cheap and cheap ain't ever cool" |
#16 |
When the fuse blows, can it also blow the relay to? I know a fuse should protect it.
#17 |
Alright so I changed out m cigar lighter and it was only part of my problem in my short. This is a link to a thread I posted on the 73-87 forum and shows also what I've done.http://forum.73-87chevytrucks.com/sm...?topic=30040.0 K so I guess I'm gonna go back threw my truck and work backwards to trace my problem. This is a scren shot of a post I found. Is this an accurate way to test and see if the shorts in my column or not?
#18 |
Moderator
![]() Join Date: Oct 2008
Download the 1985 GM Factory wiring diagrams. See below..
There are only two systems on that fuse. The horn and the lighter. The dome and footwell lamps are on Circuit #40 and are fused elsewhere. The horn button grounds the electromagnet in the horn relay so if that wire were shorted the horn would activate. Don't ask... There are two circuits in the hot side of the horn output and power feed. When are you blowing the fuse... Immediately when you plug it in (power feed) or when you push the horn button (output)? The answers will isolate the circuit to trace. If you are blowing the fuse when you push the horn button your short is in the output side between the horn relay and the horn. Trace GM Circuit #29;
If the fuse blows immediately... Your trouble is on the Power feed side. It's GM Circuit # 240 Orange wire that's entirely inside the cab;
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 01-11-2015 at 02:42 PM. |
#19 |
Sorry thought I listed model and year. Its a 1985 Chevy k10 lwb 305 with 700r4. Awesome thanks for the input. My horn fuse blows instantly when being installed.
#20 | |
#21 |
Sorry I didn't realize I forgot my year make model. It's a 1985 Chevy k10 lwb 305/700r4.
My horn fuse blows as soon as it is installed. Just making sure you said circuit #240. I only see #140. |
#22 |
Other pic
#23 | |
The ones you have pictured appear to be the "typical" / "generic" diagrams from an aftermarket Haynes or Chilton type manual and are not as detailed as the factory diagrams. The Horn fuse also protects the BATT receptacles up above it in the fuse box. So if you have any factory or aftermarket accessories plugged in there, check them and their wiring for shorts to ground too. Last edited by ray_mcavoy; 01-11-2015 at 05:30 PM. |
#24 |
Moderator
The only factory accessory plugged into the fused Batt positions is the optional clock.
Your first slide looks like a MOTOR manual. The others are from the Haynes manual. One size does not fit all... RTFM
And please let us know if and how your repairs were successful. |
#25 |
Thanks a lot Hatzie for the help in what to do on my truck and to all the others. I'll let yall know what was wrong in the wiring.
| Bookmarks |
