Old 09-13-2011, 09:50 AM   #1
Caymandave
Chasing Shorts
I did not say skirts. I have a short somewhere? Any ideas on how to start hunting it down? I used to have a Fluke Volt Ohm meter that has a small amp guage. That is long gone. I need a tool that can dectect small shorts of voltage usage.
I presume you would suggest to got to the last thing I did in the electrical department and chech that out. I replaced the 2" clock and the temp guage was not working. Mechanic said it was working when it left the shop but hasn't worked since. When I took it back he said it was something behind the dash. I took it out and check the contacts on the temp guage it had three. All seemed clean, tried to tighten them a little but no go.
Any ideas on how and where to start?
Caymandave is offline   Reply With Quote
Old 09-13-2011, 06:34 PM   #2
makman1297
makman1297's Avatar
Re: Chasing Shorts
Well, old trucks are plagued by bad, corroded connections. I would make sure all the connections are good. Gauge to cluster, cluster to wire harness, firewall connector, and the temp sensor its self. Make sure you have a good ground to your interments. If you don’t find anything visually then i would start with the volt meter (OHMS), disconnect both ends (gauge and sensor) and check the wiring to ground, if there is any resistance reading you have a short to ground somewhere. Have fun.
makman1297 is offline   Reply With Quote
