Old 09-13-2011, 12:18 PM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Spid Rear End Question
Here are 2 spid labels. The blue one is from a 71 GMC Burb and the green one is from a 72 Chev Burb. Now I think the 350 engine codes are for the same engine. I always thought the small block burbs came stock with 3:73 rear ends and the big blocks came with 3:08 rears stock. If that is the case why would the one spid show the 3:73 axle and the other not ? The main reason the guy is selling the green one ( with the 3:73's ) is because he says he cant afford to drive it. I guess my question is why is the 3:73 axle printed out on one spid and not the other ?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 09-13-2011, 05:32 PM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Spid Rear End Question
Greg...I'm gonna move this to the main board where it'll get more action
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 09-13-2011, 06:00 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
small block with an auto or 4 speed got 3.07 gears. 3.73 was if it was a manual 3 speed. So the 3.73 is listed becouse it was not base equipment with that engine/tranny combo.
Old 09-13-2011, 06:04 PM   #4
Already Gone
Thank You LM
Old 09-13-2011, 09:34 PM   #5
Longhorn Man
correction... not small block... 350. 307 engines commonly came with the 3.73 gear.
Old 09-13-2011, 10:04 PM   #6
Already Gone
That makes sense as the 307 wouldn't be as powerful as the 350 so the lower (3:73) gears would help the driveability of the heavy Burb with a 307.
Old 09-13-2011, 10:14 PM   #7
rsavage
rsavage's Avatar
My '70 2WD Burb came with a 307 and truck 4 speed. It has the 3.07 rear gear and it isn't listed as an option on the SPID.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 09-13-2011, 11:43 PM   #8
Already Gone
Thinking out loud about this a 307 with the garnny 4 speed should have reasonably good pulling power but the 3 speed autos would be a little sluggish with the 3:07 gears.
Old 09-14-2011, 06:56 AM   #9
rsavage
rsavage's Avatar
I don't know what the ratio for a 3 spd first gear is as compared to the second gear on the 4 speed, but I do know that I never had to use the granny gear to start out when I had the original 4 speed in it. I always used 2nd which is actually felt like a regular first gear.
1961 C1 Corvette
2021 Durango RT 5.7
Old 09-14-2011, 07:02 AM   #10
I believe the reason that Suburban was ordered with 3.73s is because it also had the optional L78 rubber.
Old 09-14-2011, 12:26 PM   #11
m6z
m6z's Avatar
While we're on the subject. What would be the typical gearing on a big block 1/2 ton?
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 09-15-2011, 06:56 PM   #12
Longhorn Man
3.07 unless optioned otherwise
Old 09-15-2011, 07:12 PM   #13
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
While we're still on the subject what about a C20 big block?
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 09-15-2011, 07:23 PM   #14
Longhorn Man
C/20 came with the dana rear and 3.54 gearing... again, unless optioned otherwise.
