Old 09-13-2011, 01:32 PM   #1
BMERDOC
BMERDOC's Avatar
Assembly Manual/Caulk
Can someone post a pic of how the Assembly Manual shows to lay the sealer on the windshield channel?
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 09-13-2011, 09:43 PM   #2
BMERDOC
BMERDOC's Avatar
Re: Assembly Manual/Caulk
ttt
Nick Carter
Old 09-13-2011, 11:54 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
It may be hard to read but I think you can make it out.
LockDoc
Leon
Old 01-03-2012, 12:48 PM   #4
BMERDOC
BMERDOC's Avatar
Getting ready to reinstall my windshield in the next few days. Anyone have tips, stories or general advise before I reinstall?
Nick Carter
Old 01-03-2012, 02:06 PM   #5
blkcorvair
blkcorvair's Avatar
Good Info!
blkcorvair is offline   Reply With Quote
Old 01-03-2012, 03:51 PM   #6
GRX
GRX's Avatar
Buy a few small toilet plungers, then cut the handles short. Makes moving the glass easier.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 01-03-2012, 04:01 PM   #7
BMERDOC
BMERDOC's Avatar
I already have cups for glass. I install windshields on a regular basis but this will be my first using the rope method.
Nick Carter
Old 01-03-2012, 05:14 PM   #8
72peace
72peace's Avatar
I remember reading in the service manual very good directions on using the rope method for replacing windshield, I'll try to post it when I get home. Unless someone else can put it up.
Cheers,
72peace is offline   Reply With Quote
Old 01-03-2012, 06:03 PM   #9
rsavage
rsavage's Avatar
I found a local glass guy that takes them out and puts them in for $20 a panel. I know I would break them as soon as I tried.. Had him remove the big side rear windows and the rear barn door glass on the Burb and reinstall with new gaskets last spring and then had him take the windshield out of the Blazer before it went to paint. He made it look easy but he did have a helper to palm and move the big panels on the inside. Since you do glass, should be fairly easy for you. His cord was about 1/4" in diameter.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 01-03-2012, 07:15 PM   #10
72peace
72peace's Avatar
Here's the info from the service manual: Hopefully it's not overkill, some of the figures are several pages after it references them.
Cheers,
Old 01-03-2012, 07:26 PM   #11
BMERDOC
BMERDOC's Avatar
Thanks 72Peace! I gotta get me one of them there assembly manuals!
Nick Carter
Old 01-04-2012, 12:04 AM   #12
72peace
72peace's Avatar
This was from the service manual, there's also an overhaul manual and a factory assembly manual.
Cheers,
Old 01-18-2012, 02:39 PM   #13
butler57
butler57's Avatar
Cheers,
of the 3 manuals you mention - which is the best or do you really need all 3?
butler57 is offline   Reply With Quote
Old 01-18-2012, 02:59 PM   #14
72peace
72peace's Avatar
It depends on what you want to do. The factory assembly manual is just that a no frills manual to assemble the truck, the overhaul manual covers how to overhaul the engine, trans, rearend, etc., the service manual covers routine and not so routine maintenance, e.g. replace timing belt, alternator, etc. So, again it depends on what you're planning, you may want to start with the service manual and go from there.
Cheers and happy building,
Old 01-18-2012, 03:24 PM   #15
butler57
butler57's Avatar
I appreciate the help - thanks for the reply.
Old 01-18-2012, 06:52 PM   #16
MAK191
there is a bunch of good videos on youtube here are a couple. First one has the moulding insert
http://youtu.be/eaSVkbogXNk
http://youtu.be/QDH4YkHacVo
MAK191 is offline   Reply With Quote
