Old 09-13-2011, 05:31 PM   #1
jjtackleberry
jjtackleberry's Avatar
Another Fuel gauge question
I've read the other threads, but they are a bit like German stereo instructions.
When i put a tester on the sending unit post, its grounded. In other words, my meter tones when i have one lead on the sending unit post and the other on a ground.
when i take the wire off the post the gauge goes to 3 oclock. when the wire is on the post gauge reads empty. So the reading is the same on the wire, and the post.
Any help would be great.
'71 Chevy LWB all OG
'86 Chevy LWB all OG
It's all a matter of perception
jjtackleberry is offline   Reply With Quote
Old 09-13-2011, 08:40 PM   #2
JimKshortstep4x4
Re: Another Fuel gauge question
You need a meter that reads out in ohms as the sending unit should read 0 to 90 ohms if it is working, (0=empty, 90=full).
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 09-13-2011, 11:38 PM   #3
jjtackleberry
Jim
i do have a meter that reads ohms. I guess i'm not understanding whats going on with the sender.
wire off = gauge reads 3pm
wire on = gauge reads empty
meter shows ground at sender post
meter shows ground at wire
HELP?
Old 09-13-2011, 11:55 PM   #4
Sammy
Pull the float assy. Take ohms reading picking up the float arm to simulate full should read the 90 ohms then at the bottom 0. During this process your checking only the float for correct readings so the feed wire should be off the post. If you are getting the correct readings your float is good. Trouble shoot the wire back to dash for breaks. If no breaks your problem is the dash Gage or a ground or something like that.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 09-14-2011, 12:07 AM   #5
Livrat
Member #1049
Livrat's Avatar
from your test, that tells me the fuel gauge is working.
I'll bet the float on the sender has a pin hole in it and it has filled full of gas and sunk (very common) this makes your gauge always read empty. Or it has come off the wire.
Either way you will have to pull the sender out of the tank to find out.
Livrat is offline   Reply With Quote
Old 09-14-2011, 08:01 PM   #6
Legolas894
Chemist under the hood...
Legolas894's Avatar
...or it could be the resistor is bad on the sender. Mine was really scratchy. If you ground the sending wire, it should read empty. With if off, it will read more than full. Senders are pretty cheap. If you do take the sender out, you can check the resistance on it by moving the arm gently and not very far up or down.
Current fleet:
2013 GMC Sierra, 5.3L, 4x4
1988 GMC Sierra, 305, Auto
1984 Jeep Grand Wagoneer, 360 V8
1997 VW Cabrio, 2.0L
2017 Toyota Rav4, 2.5L
Stuff I wish I still had:
2013 Toyota Matrix [RIP]
1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD]
1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD}
1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD]
1995 Chevrolet Astro AWD, 4.3L V6 (RIP)
1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD]
Legolas894 is offline   Reply With Quote
Old 09-14-2011, 11:44 PM   #7
dmack91
dmack91's Avatar
Hopefully VetVette will sign in - he helped me on mine.
If memory serves, if your gauge is reading 9 o'clock with the wire attached, the sender is grounded and needs replacing.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
