Old 09-13-2011, 06:22 PM   #1
Ackattack
Ackattack's Avatar
88+ A/C in a 67-72
It seems like I saw someone on here trying to put A/C from a 88-98 chevy truck into a 67-72.
I bought a 91 chevy for the TBI engine, but basically the entire A/C is under the dash. The metal can (dryer?) is on the engine side of the fire wall. It looks like it could fit. The thing that kinda concerns me is that it seems like the dash to the firewall in the newer trucks is deeper than our. I haven't measured or anything, but thought I'd start here.
If I can't find someone who has done it, I'll document at least trying to make it work.
Oh, and this is an R-12 system, so I'll also convert it to R-134
Ackattack is offline   Reply With Quote
Old 09-13-2011, 06:28 PM   #2
gr8one
Re: 88+ A/C in a 67-72
i would like to see more on this subject. i think it will fit.
gr8one is offline   Reply With Quote
Old 09-13-2011, 08:15 PM   #3
AirSpeed
AirSpeed's Avatar
Me too!
AirSpeed is offline   Reply With Quote
Old 09-13-2011, 08:30 PM   #4
Dark Knight
Dark Knight's Avatar
I have both style trucks and I see one major potential problem. Everything in the 88-98 style truck is electronically controlled. (As far as doors anyway). Plus, you'll have to do something about the ductwork, because everything is molded plastic and not hoses. I'm not saying it couldn't be done, just that it seems like a lot of work. But if you can pull it off I'd love to see pics too!
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS
-1983 Chevy Silverado C1500- 383 stroker, TH400
-1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears
-And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket
"The only thing we have to fear is fear itself." -FDR (and maybe rust too)
You've gotta be able to stop and steer before you can go fast!
Dark Knight is offline   Reply With Quote
Old 09-13-2011, 08:34 PM   #5
Boog
laying low
Boog's Avatar
That would clean up the engine side of the firewall pretty good. That's a lot of case that would be exposed inside the cab though. If it works for you I have a wrecked 97 complete I could do the same thing with.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 09-13-2011, 08:36 PM   #6
gr8one
i think you can change from electronic control to cable. and make ducts. Look here new than 88 but it did work http://67-72chevytrucks.com/vboard/s...Fc#post4592655
Old 09-13-2011, 08:59 PM   #7
Check out in this thread, he worked it into his burb.
http://67-72chevytrucks.com/vboard/s...d.php?t=426382
Palf70Step is online now   Reply With Quote
Old 09-13-2011, 09:06 PM   #8
Ackattack
Ackattack's Avatar
I was planning on using the 91's control panel for it. I'll come up with something to connect our hoses too A little fiberglass work never hurt anyone.
Old 09-13-2011, 09:12 PM   #9
gr8one
please post pics of progress.
