1/2ton till 3/4ton or 1 ton spindels
Is it posibel to bolt on 3/4 or 1 ton spindels on the front axle of A 1/2 ton truck. I have A 1972 GMC 1/2 ton truck and like to make it look like A dually.
Greetings Diedelson |
Re: 1/2ton till 3/4ton or 1 ton spindels
2wd or 4wd
If you can't impress them with your inteligence, dazzle'm with your stupidity 1969 GMC lwb 2wheel drive can you say big stroker motor to come hehe |
My truck is A 2wd.
67-72 parts collector,…
![]() Join Date: Nov 2002
You will need to swap the lower a-arms to 3/4-ton a-arms.
(bigger ball joint hole) Then just add the correct balljoint for the correct year spindles you are using. The outer tie rods will be different also.
Thanks for the replay.
Wen I make A bigger mounting hole in my old arms for the bigger bal joint. Woud that be oké? Thanks Koos |
![]() Join Date: Mar 2000
That is A clear NO.
But way not? |
When dealing with steering and front end component it's not a good idea to modify major components. First you would have to machine the hole on the proper angle so the taper fit exact. If you were closer I would give you everything you need. I have 3/4 ton front spindles and lower a arms with brand new ball joints that you could have. Oh and the steering linkage is larger on the c20 front end I'm pretty sure.
Yes safety first. Thanks for your replay.
