Old 09-13-2011, 08:21 PM   #1
Dalaigh
Canadian Trucker
Dalaigh's Avatar
Tpi?
I'm thinking about putting fuel injection on my 84 K20 but I have a few questions about the TPI systems. My 350 is the factory engine out of the 84 but it has 2.02 camel hump heads on it.
Will the TPI systems work on this setup? And I have a TH400 will it work with the TPI?
Anyone with pics would be nice as well?
2020 Silverado Trail Boss - 6.2/10spd
Dalaigh is offline   Reply With Quote
Old 09-13-2011, 08:58 PM   #2
79k30dually
Re: Tpi?
The stock cumputer does not like cams that aren't designed for EFI systems. Basically there are two different systems, speed density and mass air flow. You can get away with more changes with mass air flow systems, there are more differences between the two. It will be an easier conversion to find a complete engine in the car, then you'll have everything you'll need for the conversion. It's a great choice, the engine is all low end, these motors are good for about 4800 rpm's. Most rednecks couldn't figure out why they changed gears and the car went slower. Good luck, Ron.
79k30dually is offline   Reply With Quote
