Old 09-13-2011, 08:49 PM   #1
SRVBLUES64
66/350 power steering
Hi guys I have a power steering conversion questions I have 79 80s 350 motor in my 66 c10 If I went to the slavage yard what cars or truck would I look for to take the power steering pump out and install it on my 66 truck?
SRVBLUES64 is offline   Reply With Quote
Old 09-13-2011, 09:10 PM   #2
brokenspoke
brokenspoke's Avatar
Re: 66/350 power steering
The search function is your friend...try it
brokenspoke is offline   Reply With Quote
Old 09-13-2011, 10:04 PM   #3
awbrown
you have the water pump with the lug for the pump , that is the type I would look for ,just comfirm whether it is a through hole or threaded...
awbrown is offline   Reply With Quote
Old 09-14-2011, 09:51 AM   #4
chemlab
chemlab's Avatar
i just got one for mine, your pump is similar to mine but verify the lug like awbrown said, mine is threaded and i think the pump i got was a 71-79 comaro/monte carlo. the reservoir tilts slightly to the side on it. the bracket setup i got at the local resto shop.
chemlab is offline   Reply With Quote
Old 09-14-2011, 07:02 PM   #5
awbrown
Also , make sure the pump fittings match the fittings in the box , mine was a metric pump and a 3/8 flare nut on the box .. so I made my own lines , with the help of another pressure line from a older hose , flared it and flared the metric hose after cutting it to length and used a union...
Old 09-17-2011, 10:49 AM   #6
brawley
Easy Does It
brawley's Avatar
I would look at 1973-87 chevy trucks, make sure to get the mounting bracket, and pulleys needed also.
brawley is offline   Reply With Quote
