09-13-2011, 09:28 PM | #1 |
ID this part please....
Can someone tell me what this part is officially called (very far left circle)? It bolts to the frame and the idler arm bolts to it.
Secondly, when looking at this part from above, my bracket bolts to the frame and then bends to the left (away from the frame). I've looked at a couple of others but they stay in line with the frame. Is my piece damaged?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
09-13-2011, 09:31 PM | #2 |
Petroleum User
Re: ID this part please....
Idler arm support...it should have a bend
1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto 2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto |
09-13-2011, 09:37 PM | #3 |
Old member
Make sure you check the tightness of it because it will effect your steering. I found mine loose once. Saved me a ton on a rebuild sector.
09-14-2011, 12:32 AM | #4 |
can you please be more specific about the bend. i have seen one style that bends upwards and stays inline with the frame and one style that bends upwards and away from the frame. Is mine damaged?
09-14-2011, 03:02 PM | #5 |
I think I see it in the top picture, it's hard to tell but it looks like it angles away a little.
http://gmpartswiki.com/getpage?pageid=22480 - Ian |
