Old 09-13-2011, 10:48 PM   #1
motiveauto
motiveauto's Avatar
Drop Spindle Clearence Headache
I bought some spindles off of CL. They are for a 73-87 c10 (I swapped in a 84 c10 front crossmember and assembly) and use the 1" rotors....
Heres the Problem: Im using a set of 15" steel 5 lug wheels from an 88 and up half ton and they are grinding on the steering arm. I put in a 5/16 wheel spacer and still i have the problem. I dont really want to go any bigger with a spacer. Anyone have any ideas?
86 K20 6" lift
66 C10 LS2 T56
1947 Ford Rat Rod
Softail Deluxe
Softail Chopper
motiveauto is offline   Reply With Quote
Old 09-13-2011, 11:12 PM   #2
SCOTI
SCOTI's Avatar
Re: Drop Spindle Clearence Headache
Use 5-lug wheels for the 71-87's.
Use narrower van ralley wheels from 73-87.
Trim the a-arm lip in conjunction w/the spacer for the current wheels.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-13-2011, 11:15 PM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
The offset on 88+ wheels are too deep. With dropped spindles, it only magnifies the problem, since the wheel lip moves closer to the steering arm.
Either get different wheels or you're going to have to use bolt on spacers, likely about 1.5" ones.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 09-14-2011, 09:47 AM   #4
kieth
kieth's Avatar
But when you add spacers with that wide a wheel it will create its own set of problems with the fender lip when turning, I was planning on using a set of 5 x 5-15" x 7 van rallyes so everything would clear, the wide wheels are not a problem at the rear.....Kieth
kieth is offline   Reply With Quote
Old 09-14-2011, 12:25 PM   #5
chevy_mike
chevy_mike's Avatar
Agreed, that is why I went with 15x7 slot mags instead of 15x8's. I didn't want to chance the clearance issues.
I think this becomes less of an issue with 17"+ size wheels as the lip is further away from the steering arm.
Old 09-14-2011, 12:32 PM   #6
SCOTI
SCOTI's Avatar
If the back-spacing is the same on a larger diameter wheel (vs. a 15" wheel), the contact will just be made in a different area. I had to trim the a-arm lip even w/18x8" wheels because they had 5.25"bs.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
